Plywood Wall Sheathing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 06:31 PM   #1
Plywood wall sheathing
What size of plywood should I use when framing? It's an exterior wall of a garage. I'll be putting up vinyl siding if that effects the size. OSB or plywood??
Cheers
Hrose77 is offline   Reply With Quote
Old 06-29-2011, 06:40 PM   #2
Rewards Points: 5,336
Cheers
You can go as thin as 1/2" if you want. Either OSB or plywood will satisfy building code, but I'd check just in case. Or you can hang on a bit and Gary will be by to link you up to code info.
It would help if you stated where you live.
Personally I only use 3/4" exterior grade ply.
Ron
B. Franklin 1759
Old 06-29-2011, 06:57 PM   #3
I live in BC, Canada, not sure what the code is here.
Old 06-29-2011, 09:05 PM   #4
Don't you need to know the code to build the structure?
Ron
B. Franklin 1759
Old 06-29-2011, 09:46 PM   #5
I am fixing a rotten wall and replacing the covering so structurally not changing anything.
Old 06-29-2011, 09:53 PM   #6
Rewards Points: 558
use 3/4" exterior grade ply and you wont have any problems.
epson is offline   Reply With Quote
Old 06-29-2011, 09:55 PM   #7
Older garages were sheathed with ship lapped 1x8's around here.
I'd replace the damaged wood with the same thickness material.
Ron
B. Franklin 1759
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
coverin plastic tile wall with panelin or thin plywood. how to cover the seams? chinolofus Remodeling 2 11-23-2010 07:52 PM
plywood/ osb scraps for sheathing? nicole21 Roofing/Siding 4 09-08-2010 11:41 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
