Plywood-Putting Up - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 07:31 PM   #16
kwikfishron's Avatar
Rewards Points: 348
Originally Posted by Hrose77 View Post
What is "blocking" that people are referring to?
Anywhere I’ve ever worked the wall sheathing must have full perimeter nailing.
If you run the sheets vertically this is achieved by the studs and the top and bottom plates.
If you run the sheets horizontally the top edge of the first row of sheets will only have the studs to nail to. You need to add a row of blocking between the studs for nailing.
The blocks not only for nailing but also a fire stop.
If the sheathing is installed as mentioned (horizontally with no blocks and a gap between the sheets) this would be inviting fire to enter the wall cavity.
Look around at new construction I doubt you will see many if any with horizontal sheathing. Any strength it may add is outweighed by the extra material and labor cost to the framer.
Plumbers and electricians don’t think much of it either.
kwikfishron is online now   Reply With Quote
Old 07-02-2011, 08:03 PM   #17
KemoSabe
loneframer's Avatar
It's a regional thing. I framed along the East Coast of NJ for 20 years. Never was blocking required for perimeter nailing on exterior sheathing and it was installed horizontally 99% of the time.
We always space our seams and edges. Many of the buildings are less than 10' apart in some communities.
4' setbacks required fire rated sheathing panels, 5' did not, however all bearing walls were required to have 5/8 Type X drywall on the interior.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 07-02-2011, 08:57 PM   #18
Registered User
Rewards Points: 5,466
Not the distance, as loneframer said: http://publicecodes.citation.com/ico...9_3_sec002.htm
I don’t think the blocks were for fire-stop, only at ceiling/floor and every 10’ horizontally: http://publicecodes.citation.com/ico...002_par031.htm
Blocking is for shear walls as I quoted above, depends on your location for the seismic/wind design: http://publicecodes.citation.com/ico...001_par004.htm
The shear values are way different depending on orientation without blocks: http://www.trioforest.com/pdf/Load-Span_Tables.pdf:, Table 1: The blocks even it out, though I have no idea how much.....
Example: http://www.awc.org/pdf/WFCM_90-B-Guide.pdf
Gary
Old 09-25-2011, 08:59 AM   #19
If nailed incorrectly sidewall installed would corner bracing fix the problem with the integrity of the structure
djc125 is offline   Reply With Quote
Old 09-25-2011, 09:38 AM   #20
Rewards Points: 2,238
"djc125"
What kind of corner bracing are you referring to?
"Let-in" - "T-strips" ...
rossfingal
rossfingal is offline   Reply With Quote
Old 09-26-2011, 08:16 PM   #21
It's pretty much all horizontal here, considered pretty standard. No blocking between sheets where they meet horizontally, quarter inch or so gap left between the sheets horizontally, most guys stick a pencil in between the sheets to get the gap. No worry about fire blocking since this is done between floors. Sheets are returned over openings, no joins at the corner of a RO.
Interesting how things are different from region to region.
chrisBC is offline   Reply With Quote
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-24-2011 11:58 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
How to install 3/8 underlayment plywood? dangdang Flooring 8 09-26-2009 04:21 PM
Thickness of cement board on plywood ceiling hacksepe Building & Construction 5 09-13-2009 07:07 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 08:48 PM
