Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-26-2009, 01:06 PM   #1
plumbing vent problem
Over the last year or so, a vent problem has been getting worst. When the washing machine is emptying the water down the drain, there does not seem to be enough venting for it. Air and water bubble up in the toilets and it sucks the water out of the toilet bowls as the water leaves the washer. I thought that maybe the vent stack was blocked, but nothing is in it.
What could be causing the lack of venting in this case?
hydroguy is offline   Reply With Quote
Old 05-26-2009, 01:56 PM   #2
Sounds more like a partially clogged main drain. It can back up and block the vent pie. Washers put out a lot of water in a short period of time. This is why newer codes require 2" instead of 1-1/2" discharge piping for them.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
bathroom vent fan - condensation problem jaspar General Discussion 16 03-23-2012 11:54 AM
Problem with whole house fan and not enough attic/roof vent area keeena Roofing/Siding 11 06-16-2008 12:59 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Plumbing vent flashing FatAugie Roofing/Siding 7 08-24-2007 09:30 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
