Plumbing Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 09:51 PM   #1
plumbing problem
Need help bad !!! I live in a mobile home and I'm having a problem with my plumbing in the kiitchen/bathroom area. My kitchen sink drains but some water goes to the bathrom tub and just sits in tub, also how to build up septic tank outside my septic tank is on a hill and with any heavy rain it fills up. Can a mound of dirt be placed on tank to slow rain water from entering the tank ????
mrdj0022 is offline   Reply With Quote
Old 08-17-2011, 10:03 PM   #2
DIY staff
Rewards Points: 7,174
Pictures will help----where is the leach field? Does that get flooded when it rains?
Old 08-17-2011, 10:04 PM   #3
Rewards Points: 262
Rain water should not be getting into your sepeic tank. It is a closed system. It sounds like you either have a cesspool or a dry well if it is filling up from rain water.
The water going from the sink to the bathtub could be a septic system that is overwhelmed or it could simply be an obstruction downstream from the sink and tub.
Jim F is offline   Reply With Quote
Old 08-17-2011, 10:31 PM   #4
Thank you I'm not familar with the term leach field??? As I stated ceasepool/septic tank is in ground on a hill, rain runs into septic tank/ceasepool when it rains there only a concrete cover over septic/ceasepool area. please what area doi take photos of ?????
Old 08-17-2011, 10:33 PM   #5
plumbing problem
[quote=Jim F;709640]Rain water should not be getting into your sepeic tank. It is a closed system. It sounds like you either have a cesspool or a dry well if it is filling up from rain water.
The water going from the sink to the bathtub could be a septic system that is overwhelmed or it could simply be an obstruction downstream from the sink and tub.[/quote
How to clear up this problem ?????
Old 08-17-2011, 11:03 PM   #6
Rewards Points: 5,336
[quote=mrdj0022;709662]
When was the last time the cesspool was cleaned out?
I would probably call a cesspool cleaner who will pump out the basin.
Ron
B. Franklin 1759
Old 08-17-2011, 11:24 PM   #7
Too Old
http://inspectapedia.com/septbook.htm
Have a look at this for some information which may help you understand issues and solutions.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
airgap plumbing code problem airgap Plumbing 18 03-13-2014 12:33 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
Plumbing leak in basement - HELP jamieblosser Plumbing 2 06-16-2011 12:44 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
