Plug-in Receptacle? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-22-2009, 04:24 PM   #1
Plug-in Receptacle?
Hi all,
I saw an ad for the "power bridge solution" http://www.powerbridgesolution.com/ which uses a "reversed outlet" i.e., you plug the female end of an extension cord in to give the receptacle power which then goes to the wires/etc.
Is this a new type of receptacle? Or are those available elsewhere? (I just want the power receptacle, not the t.v. stuff).
Thanks!
prc114 is offline   Reply With Quote
Old 12-22-2009, 05:18 PM   #2
Advice worth 2 cents!
Rewards Points: 150
Cool Product! If you want just the receptacle you need to find a "Clock Receptacle" it's recessed just like the one in the photo.
_pete
---pete
HandyPete is offline   Reply With Quote
Old 12-22-2009, 06:19 PM   #3
Monoprice has a similar one for a little less. It still has the pass through for the LV wires, though. I used it to connect my tv to a ups/surge protector.
jerryh3 is offline   Reply With Quote
Old 12-22-2009, 06:40 PM   #4
$100
I'll just connect a recessed outlet behind the TV myself
YUp - get a clock receptacle
The advantage I see to this setup is that you can plug it into a UPS
Old 12-22-2009, 06:50 PM   #5
Safe, Most of the Time!!
brokenknee's Avatar
edit: uncalled for comment. Should have check OP other post before commenting.
My apologies.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 12-22-2009, 06:58 PM   #6
If that is the case then spammers have a new method based on his other posts
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 07:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 06:36 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 10:28 AM
