-   -   Plug-in Receptacle? (http://www.diychatroom.com/f2/plug-receptacle-59788/)
prc114 12-22-2009 03:24 PM
Plug-in Receptacle?
Hi all,
I saw an ad for the "power bridge solution" http://www.powerbridgesolution.com/ which uses a "reversed outlet" i.e., you plug the female end of an extension cord in to give the receptacle power which then goes to the wires/etc.
Is this a new type of receptacle? Or are those available elsewhere? (I just want the power receptacle, not the t.v. stuff).
Thanks!
HandyPete 12-22-2009 04:18 PM
Cool Product! If you want just the receptacle you need to find a "Clock Receptacle" it's recessed just like the one in the photo.
_pete
jerryh3 12-22-2009 05:19 PM
Monoprice has a similar one for a little less. It still has the pass through for the LV wires, though. I used it to connect my tv to a ups/surge protector.
Scuba_Dave 12-22-2009 05:40 PM
$100 :eek:
I'll just connect a recessed outlet behind the TV myself
YUp - get a clock receptacle
The advantage I see to this setup is that you can plug it into a UPS
brokenknee 12-22-2009 05:50 PM
edit: uncalled for comment. Should have check OP other post before commenting.
My apologies. :blush:
Scuba_Dave 12-22-2009 05:58 PM
If that is the case then spammers have a new method based on his other posts :laughing:
