Pls Help! DIY Foundation Crack Repair Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 10:45 PM   #1
Exclamation
Pls help! DIY foundation crack repair question
We are using a DIY Epoxy injection kit to seal cracks in the crawlspace. You are supposed to surface seal the OUTSIDE of the crack as well as the INSIDE, but there is not access to the outside of the crack due to a deck & garage. Will the repair still work, or what should we do? Thank you to anyone who can help!
tspaulin is offline   Reply With Quote
Old 07-15-2009, 03:15 PM   #2
Registered User
Rewards Points: 5,216
The repair will not work on the inside. I would dig a drain tile line around the water affected wall, and drain it away from said area. That would stop any sub-soil water from lateral capillary action but not sub-terrain water(spring). Be safe, G
Old 07-16-2009, 07:30 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
If it's a poured concrete wall and the crack injection is properly done, it can be successful. Under the circumstances, you don't have many options. Be sure that the injection ports are spaced closely and that they are run the full length of the crack. If the crack is injected only at the low point where it appears to be leaking, the water level could rise and just come in higher. I've seen it happen.
Old 07-16-2009, 08:39 AM   #4
General Contractor
Generally speaking if the manufacturer instructions call for sealing from both sided that is what you should do. If you don't you are probably just wasting your time and money. That is the way the product was engineered to work so that is how it should be applied.
ARI001 is offline   Reply With Quote
sill plate repair over block foundation MARLE Building & Construction 14 05-04-2009 09:03 PM
Concrete Foundation Question Teresa1127 Building & Construction 6 10-19-2008 01:23 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Repair Opening in concrete foundation jr66 Building & Construction 2 05-14-2007 12:32 AM
