Please Review My Sequence For Painting And Trim Work....New Construction - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-25-2015, 07:38 PM   #1
Rewards Points: 14
Please review my sequence for painting and trim work....New Construction
Hey Guys,
I just found this place and am happy to be here
I have a question about my steps regarding painting and trimming out my new home that I am building. I was going to do the following sequence of steps because it seemed easier to me without the taping and such.
1- Spray Primer on all ceilings and walls.
2- Spray first and finish coats on Ceiling
3- Spray first and finish coats on walls
4- Spray primer and finish coats on Crown Molding, trim, casings and pre-hung doors on sawhorses BEFORE installing them.
5- Install all of above casings, moldings, trim and doors.
6- Fill all nail holes, caulk gaps on above casings, moldings, trim and doors and then touch up with paint.
Does this sound right? (I have both an airless sprayer and an HVLP system). What has me concerned is that I was reading the forums with the Pro's and a lot of them seem to recommend installing trim, casings, moldings, etc...BEFORE spraying the finish coat. They also then recommend applying the final coats on the walls last.
It just seems easier to me to have all of the walls done before any of my trim is installed. Also I would think I should spray finish coat on all trim before installation? The way the Pro's are recommending seems to mean extra work to me (taping and such that I would not have to do if the walls already had the final coats) but I am sure these guys know what they are talking about. Where am I going wrong?
Please note that I am building the house myself and doing 90% of the work including building and installing my own cabinets, plumbing and electrical. Does this matter? Are the Pros worried about other contractors screwing up their paint job?
Thanks a bunch guys
homeby5 is offline   Reply With Quote
Old 07-26-2015, 08:26 AM   #2
Rewards Points: 5,256
The way your suggesting is the way I've done new constrution for many years.
Someone's going to mention something about the touched up areas "flashing".
I use light weight drywall filler like Fast and Final to fill the nail holes and it has not been an issue for me.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
ToolSeeker (07-26-2015), Windows on Wash (07-27-2015)
Old 07-26-2015, 11:58 PM   #3
Rewards Points: 2,785
In 30 years I have never put a primer on drywall.....
ron45 is offline   Reply With Quote
Old 07-27-2015, 06:05 AM   #4
Rewards Points: 14
So my steps look right then...
As far as drywall primer goes, I know some don't use it but I like to.
Thanks guys
Old 07-27-2015, 06:16 AM   #5
Rewards Points: 4,254
Gotta agree would not do it without primer.
Entering your general location can help with answering a lot of times
The Following User Says Thank You to ToolSeeker For This Useful Post:
joecaption (07-27-2015)
Old 07-27-2015, 07:59 AM   #6
And no primer and paint in one for new drywall!.
Old 07-27-2015, 05:04 PM   #7
Rewards Points: 14
No....I bought Kilz drywall primer.
Old 07-28-2015, 02:21 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 2,734
no comment there
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (07-28-2015)
Old 07-28-2015, 07:22 AM   #9
Rewards Points: 179
That's the way I'm doing the house I'm building. I'm brushing and rolling everything, though. I do most of a full coat when touching up- at least the flat areas, but not the edges. I'm using Benjamin Moore Advance for trim work- great stuff! I pre-painted everything on the outside of the house, too, but applied a second coat once all the siding was hung.
MushCreek is offline   Reply With Quote
Old 07-28-2015, 04:36 PM   #10
Rewards Points: 14
I prefer BM paints also. Let me ask, for spraying the trim does good quality paints matter? I know they matter when brushing and rolling because of coverage and ease......
Old 07-28-2015, 06:34 PM   #11
Even more so.
Old 07-28-2015, 06:41 PM   #12
Rewards Points: 14
Could you explain please? Do they cover better with a sprayer just like they do with a roller?
I guess what I'm asking is that when I first started using quality paints I noticed they actually would cover in one coat instead of two when I rolled which obviously afforded me less work and justified the extra cost. They also required less effort to apply when rolling or brushing.....they went on like butter. With a sprayer I am concerned that I will not get the added benefits. Thanks Guys
Old 07-28-2015, 09:27 PM   #13
The better coverage is not because of the way you put it on, the better coverage is because better paints have better ingredients (binders, pigments, etc) If you spray a bad paint you get bad results, If you brush and roll a bad paint you get bad results.
homeby5 (07-29-2015)
Nail hole filler for finished trim work ffgreg Painting 2 09-29-2009 11:21 AM
oil vs latex for trim work NoExperience Painting 7 08-31-2008 03:42 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
