Plastic Wall Anchor With Different Screw - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 02:47 PM   #1
Lightbulb
plastic wall anchor with different screw
I screwed a metal mesh file organizer onto drywall, using plastic wall anchors with the screws it came with. But now i found the original screws that came with the mesh file organizer. The original screws are a bit thicker than the ones i just screwed in. Will the plastic wall anchors still be okay if i use these original screws?
I prefer the original screws because the screw-head is larger in circumference & presses against the file organizer better. I'm worried if i remove the screws i just used, the plastic wall anchors will be unusable.
DiyCR fan is offline   Reply With Quote
Old 05-21-2013, 03:25 PM   #2
joed's Avatar
Rewards Points: 11,560
The plastic wall anchors should be fine when you remove the screws. However if the new screws are a larger size then the anchors may be too small and split with the new screws.
The Following 2 Users Say Thank You to joed For This Useful Post:
DiyCR fan (05-21-2013), mae-ling (05-21-2013)
Old 05-21-2013, 03:38 PM   #3
Too Short? Cut it Again!
Ditto this. If you want to use the larger screws, you should go to the store and get matching screw anchors.
The other thing that may happen anyhow when you try to take the screws out of the anchors you have is that the screw and anchor will just spin as a unit. In this case, you would need larger screw anchors anyhow to compensate.
I think they sell an assortment of screw anchors which can come in handy although as with most such things, there are probably sizes included you will never use. In any event, plastic screw anchors will not break the bank.
The Following User Says Thank You to user1007 For This Useful Post:
Old 05-21-2013, 07:17 PM   #4
Rewards Points: 12,818
First thing I do with those anchors is toss them in the trash.
Almost no holding power, most spin in the hole when the screw goes in.
I use these instead.
http://www.bing.com/shopping/e-z-anc...M=EGCA&lppc=16
Old 05-21-2013, 09:37 PM   #5
Thank you all... joecaption those are nice screws ty
Old 05-21-2013, 10:17 PM   #6
Msradell's Avatar
Rewards Points: 84
That Same Style Is Available made in plastic instead of metal. They work just as well in sheet rock, but won't go into a stud if you hit one. They are certainly much better than the small expanding plastic ones that come with most items.
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Old 05-21-2013, 11:35 PM   #7
joed's Avatar
The link is to nothing related to screws for me. All I see are laptops and projectors.
Old 05-22-2013, 01:31 AM   #8
Like anything else, you have to match anchors to the task at hand. There is absolutely nothing wrong with the little plastic plug type for holding say the ends of towel racks. Two of those you love would never fit next to each other and would tear up the drywall. There are also plastic expansion butterflies and things when more hold is needed. You pick the hanger system for the task at hand.
DiyCR fan (05-24-2013)
Old 05-22-2013, 05:48 PM   #9
Lord of Slums
Rewards Points: 1,974
Sorry guys, I really do not like that link that Joe posted. A good toggle and you are done.
mj12 is offline   Reply With Quote
Old 05-22-2013, 06:15 PM   #10
How did we get from a size or two up plastic anchor, that will work fine, to needing a toggle? To hold a light duty basket?
Old 05-22-2013, 08:17 PM   #11
Lord of Slums
The poster is more worried about the size the the head. Strength was never mentioned. If it was my file going in that basket you would probably need to hit the studs.
The Following User Says Thank You to mj12 For This Useful Post:
Old 05-24-2013, 04:06 PM   #12
Thumbs up
Ty all. I removed the plastic anchors. I see they can be reused except for one because i mangled it getting it out. But i installed new plastic anchors that match with the original screws i really wanted to use (that have the larger diameter screw head).
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 05:56 PM
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 10:48 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
How to repair a ABS soil stack with a drywall screw in it? ThatGuy Plumbing 10 02-22-2012 11:36 AM
Plastic on basement wall kupalino Carpentry 6 10-16-2009 04:05 PM
