Plastic Fascia And Soffit Panel Attaching To It. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 12:24 AM   #1
Rewards Points: 562
Plastic fascia and soffit panel attaching to it.
I sure like the looks of the 3/4" by either 4 or 6" plastic lumber stuff as fasia board. About the same price when you have to buy the wood fascia and cover it with alluminum fascia cover.
BUT, with wood fascia you nail soffit panel to bottom of fascia, then cover the nasty edge with cover.
with plastic fascia do you attach another nailer board on the back side of it to hold soffit end,,,recess it inside itself?? Do they make basicly 1 X 2 plastic to atach to back side for a nailer strip??
With 2 X 4 rafter tails and 4 inch Certainteed or aztec trim do you bob the bottom of the rafter tails to have enough space??
Thanks for any suggestions!!-don-
4just1don is offline   Reply With Quote
Old 07-22-2009, 09:26 PM   #2
Rewards Points: 562
NO opinions??
Rotted Soffit and Fascia boyfly Carpentry 1 05-08-2009 10:12 PM
What type of wood is used to replace soffit and fascia board? creamaster Carpentry 6 07-16-2008 01:20 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
