Plaster Walls That Sweat - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-02-2010, 08:33 PM   #1
Plaster walls that sweat
I have a rental property that has plaster walls (old style house) behind the paneling. Evidently the plaster is sweating....as there are mold spots on the wall. Is there a way to remedy this without removing all the paneling and the plaster?
minus is offline   Reply With Quote
Old 07-03-2010, 05:33 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 320
Dehumidifier?
Old 07-03-2010, 09:20 AM   #3
bbo
you really need to fix the source of the sweating. if you have water in a structure you should really fix the source of the water first before you hide it with a cosmetic fix.
bbo is offline   Reply With Quote
Old 07-04-2010, 12:20 PM   #4
Rewards Points: 5,336
Where are you?
How much humidity is there that it's condensing on a plaster wall behind paneling? How do you know it's behind the paneling?
If moisture is trapped behind a substrate, that substrate needs to be removed and mold remediation needs to take place.
As bbo stated, the moisture issue needs to be addressed.
Ron
Repairing Hairline Cracks in Plaster Walls jerome8283 Painting 8 11-17-2011 07:43 AM
help with plaster walls... bcbud3 Remodeling 0 06-21-2010 03:19 PM
New Wiring Behind Plaster Walls nxl Electrical 5 12-12-2009 09:31 AM
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 07:42 PM
waterproof plaster shower walls carsokk Remodeling 2 01-31-2008 08:14 AM
