Plaster Of Paris Safety - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 10:14 AM   #1
Question
Plaster of Paris Safety
How safe is Plaster of Paris?
I am thinking of using it for arts and craft. I have seen a lot of video on youtube where people mix it by hand (and it seems like there is no need for mask or goggle). While I won't mix it that way myself, I can't get rid of the image of some of the dust getting into my eyes or lungs and solidify there.
I know it is a widely used material, so it should not be too bad, but if I use it for arts purposes, it is going to be more than once-in-a-couple-of-years type of drywall or repair job, so I thought I would ask first.
Many of you guys are professionals, so you are using it more often than a typical houseowner. So what do you think?
I don't know if this is the right forum to ask this. If not, I apologize in advance.
Dave in Michigan is offline   Reply With Quote
Old 01-22-2011, 11:04 AM   #2
Household Handyman
Rewards Points: 1,408
My only experience with Plaster of Paris was when they used it to make casts for broken bones. I had plenty of experience with those. I do remember that years ago, the Dr. and/or nurses would use their hands to mix the stuff up in bucket, then put it on with bare hands. The in later years it seems they started wearing something like surgical gloves. Don't know if they learned something over time or what. The last few casts I have had were the hi-tech ones made of a fiberglass material with the resin impregnated within the material. Just soak in hot water, apply, and your done. NO, I don't go breaking a lot of bones, just some weird curvature of the left femur and they've tried to twist it back for years without doing surgery.
Old 01-22-2011, 11:12 AM   #3
Rewards Points: 5,336
All you need to do is gently handle the product. Use common sense and a dust mask if it makes you feel better.
Ron
Old 01-22-2011, 12:33 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
It hasn't contained lead for several years, so just wear a dust mask.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-22-2011, 05:07 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 358
Ayuh,.... I'd say it's about 1% more Dangerous than sifted white flour.....
Bondo is online now   Reply With Quote
Old 01-23-2011, 10:08 AM   #6
Thank you all for the replies! This makes me feel much more comfortable with using the material. It sounds like if proper precautions are taken, plaster of Paris is pretty safe.
Old 01-26-2011, 01:47 PM   #7
Buy it from a craft shop
Buy it from a hobby/craft shop it will be child/skin friendly. Buy it from a DIY store and it might contain more gypsum. Be aware when the gypsum and water in it mix they cause an exothermic reaction when in bulk can reach up to 60 degrees. So just take your hands out if it feels warm!
Angry_D.I.Yer is offline   Reply With Quote
Old 01-26-2011, 02:29 PM   #8
Registered User
Termite's Avatar
If 60 degrees feels warm then you're probably dead anyhow!
Old 01-26-2011, 03:10 PM   #9
Bondo's Avatar
Rewards Points: 358
Ayuh,... My guess is, He's talkin' Celsius....
Considerin' he's postin' from accross the Big Pond...
Plaster Walls? I dont know? chsitko Drywall & Plaster 4 08-28-2010 06:30 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Right materials to patch plaster on masonry? jimhome Remodeling 3 06-08-2009 12:23 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
