Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-26-2011, 09:52 AM   #1
Pipe noises
Hi all,
I have been hearing noises in my water pipes throughout the day. The noise sounds like the water is rushing/filling the pipes. Not a violent sound by any means and lasts only a few seconds. There are no faucets open or appliances used when this happens. The house is 9 years old and no previous plumbing issues. I have turned the main off and turned all the ground level faucets on to drain. I also checked to make sure the kids didn't leave the hose on. Finally, I don't think we have any leaky toilets, but all I did for that was the look/listen test. So here I am looking for help... thoughts?
FF_Thor is offline   Reply With Quote
Old 05-26-2011, 10:37 AM   #2
Super Moderator
Pipe noises
I'd bet on a toilet flapper that is causing the toilet to refill occasionally.
Turn off the toilet shut off-----check the water level in the tank after two or three hours, If it's gone down ,you have caught the suspect.--Mike--
Old 05-26-2011, 03:14 PM   #3
Pipe noises
Would I still be hearing the noise if the toilet was shut off?
Old 05-26-2011, 06:23 PM   #4
Super Moderator
Pipe noises
No--if the water is off to the toilet and you still hear the noise---there is something else to blame.
Old 05-26-2011, 06:56 PM   #5
A Little Of Everything
Pipe noises
I agree with what Mike is saying. The little toilet stopper mechanism, in the tank of the toilet, will eventually deteriorate, and let water seep out of the tank. It's very common, and not hard or expensive to fix.
DrHicks is offline   Reply With Quote
Old 05-26-2011, 07:04 PM   #6
Pipe noises
2 other items:
Do you have outdoor sprinklers?
Ice maker in fridge?
diyorpay is offline   Reply With Quote
Old 05-26-2011, 08:38 PM   #7
Average Joe/ex-Navy IC3
gregzoll's Avatar
Pipe noises
If no check valve is in place to keep the house water from back-feeding into the public water supply, what you are most likely hearing, especially during the Summer months, is the water pressure dropping due to Hydrant testing, and especially in a business district, due to people using the public water supply. Contact your utility and see if they can monitor the water pressure on your home, and check for any leaks, since infrastructures are getting worst now that cities are deferring maintenance until the line breaks somewhere.
Also, update with your location, so others know where you are to better help you.
The Following User Says Thank You to gregzoll For This Useful Post:
federer (05-27-2011)
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
