Pin Nailer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 11:16 AM   #1
Pin Nailer
Hey,
Iam in the market for a Pin Nailer, and was woundering what are some of the Good ones, I dont want to spend 300 dollars, just a Good one for some Home projects, But I am a firm beliver in you get what you pay for?
splinter2 is offline   Reply With Quote
Old 09-22-2010, 11:56 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 530
Senco and Pasload pop into my mind first as I have always had good luck with both products in all they made. Bostitch, Porter Cable, and Duo-fast are three more. The cost shouldn't be in the $300 range for one now days where in days gone by all guns were $300 and up.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-22-2010, 03:11 PM   #3
SDC
SDC's Avatar
I install my fair amount of kitchens, nothing wrong with the porter-cable
http://www.homedepot.com/webapp/wcs/...2&marketID=260
SDC is offline   Reply With Quote
Old 09-23-2010, 08:28 AM   #4
jlhaslip's Avatar
Rewards Points: 2,748
Porter-Cable has been working for me for 10 years.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 09-23-2010, 07:56 PM   #5
firehawkmph's Avatar
Rewards Points: 1,898
Check home depot for the porter cable. I thought I just saw it in todays ad for $65 or $69.00. I have had one since they came out. Works well for pinning along with glue.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 09-27-2010, 12:19 PM   #6
RDS
Rewards Points: 150
I've been happy with my Porter-Cable pinner also.
RDS is offline   Reply With Quote
Old 09-27-2010, 08:22 PM   #7
Rewards Points: 286
What is the advantage of a pin nailer over a brad gun?
Jim F is offline   Reply With Quote
Old 09-27-2010, 08:40 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 530
A pin nail is basically a needle as it has no head and is about the size of a needle where the brad nail has a head and is thicker. I like the pin nail as it will hold the smallest trim or piece of wood in place for the glue to dry and will not split the smallest wood pieces. I used it a lot in putting crown molding around something with a lot of steps because I could glue and pin all my pieces together on the ground and put it up all at once.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Jim F (09-28-2010)
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 01:16 PM
Which cordless nailer should I buy? Mike2181 Tools 8 09-23-2009 01:04 PM
Hardwood Nailer and Compressor - HorsePower/PSI or SCFM? hwood Flooring 3 03-04-2009 03:11 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 11:24 AM
