Pilot Tube On Gas Logs Glows Oragne - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 10:31 PM   #1
Pilot tube on gas logs glows oragne
I have a set of propane gas logs. Each season, in order to get them to relight, I have to undo the connections, blow them out and relight the unit.
I've just done that, and the unit is working. But I've noticed the end of the pilot light tube is orange (heat).
I have not noticed this in previous years. Fireplace seems to be working fine but I'm concerned about this tube being too hot.
Is this a safety hazard? I would anticipate this tube will melt/disingrate over time.
Thanks for any help.
harryhal is offline   Reply With Quote
Old 12-01-2010, 12:19 AM   #2
Rewards Points: 372
The tip should be in the flame and orange is OK. There should be flame impingment about 3/4 of the length from the end. And yes, the tube will melt/disintegrate over time. When that happens, replace the thermocouple.
fireguy is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 05:58 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 09:11 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
