Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-11-2011, 09:54 PM   #1
Pilot light on water heater
Pilot light on GE water heater goes out when burners go off. I'd hate to replace the thermalcouple if that isn't the problem cuz it comes in a pilot assembly and costs about $40.
jbjones is offline   Reply With Quote
Old 04-11-2011, 11:23 PM   #2
You can pick up a thermocouple for under $10.00. If you can't replace that, call in a plumber.
Ron
Old 04-12-2011, 08:51 AM   #3
Try and tighten up the nut that goes into the regulator. That may fix it if not go to a box store and get a thermacouple like was mention around $10.00 . The universal will work length doesn't mean anything as long as it is long enough . If you have to get a longer one juse put a big loop in it . Don't kink it tho. good luck have fix many of them nothing to it
del schisler is offline   Reply With Quote
Old 04-13-2011, 07:30 PM   #4
Just to update, the problem ended being the gas control valve. Thanks for trying to help
Gas water heater - after long use pilot goes out. paulsaindon Plumbing 1 07-14-2011 05:51 PM
Water heater won't light adfuhrer HVAC 1 12-10-2010 03:59 PM
Water heater won't light adfuhrer Plumbing 0 12-10-2010 03:11 PM
Problems with water heater jwise Plumbing 11 02-26-2010 08:36 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
