-   -   Pilot light on water heater (http://www.diychatroom.com/f2/pilot-light-water-heater-101234/)
jbjones 04-11-2011 08:54 PM
Pilot light on GE water heater goes out when burners go off. I'd hate to replace the thermalcouple if that isn't the problem cuz it comes in a pilot assembly and costs about $40.
Ron6519 04-11-2011 10:23 PM
You can pick up a thermocouple for under $10.00. If you can't replace that, call in a plumber.
Ron
del schisler 04-12-2011 07:51 AM
Try and tighten up the nut that goes into the regulator. That may fix it if not go to a box store and get a thermacouple like was mention around $10.00 . The universal will work length doesn't mean anything as long as it is long enough . If you have to get a longer one juse put a big loop in it . Don't kink it tho. good luck have fix many of them nothing to it
jbjones 04-13-2011 06:30 PM
Just to update, the problem ended being the gas control valve. Thanks for trying to help
