Phone Wire - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-12-2007, 08:52 AM   #1
phone wire
I am instaling or repairing a phoneline in my house. the wire that is comming up the wall and throught the wall has 6 wires. green,white w/green,bule, white w/ blue, orange, white w/ orange. i tried connecting the wires up but i get not dial tone. i know the phone works cause it works every where else in the house. are there extra wires that i don't nee to connector what. what is going on and what wires need to be conected?
thanks
JAVAMAN is offline   Reply With Quote
Old 12-12-2007, 10:43 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,......
Most residentail installations only use 2 of the wires,.......
Take a known working phone outlet apart,+ See which 2 the installer used......
Old 12-12-2007, 09:21 PM   #3
remodeling pro
Like Bondo said, start by seeing which two colors are the "hot" pair ona working jack. Unfortunately along the way, someone could have switched "pairs" of colors multiple times during repair or addition of jacks.
troubleseeker is offline   Reply With Quote
Old 12-13-2007, 03:26 PM   #4
Rewards Points: 6,652
It will either be the Blue & Blue/White pair, or the Green & Green/White pair. You have a 3 Pair wire it sounds like (Green, Blue, Orange).
Old 12-13-2007, 04:34 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
You can use any pair you like, as long as you do the same on both ends.
Old 12-13-2007, 05:24 PM   #6
Rewards Points: 5,336
You can use a simple headphone headset to hear which two wires are energized. Touch one to the tip and one above the black insulating collar. When you hear a dial tone, you're good to go.
Ron
Old 12-13-2007, 10:09 PM   #7
thanks
Analog phone lines use the four-color standard of red, yellow, green and black. As many others already stated, only two are actually used. However, the question appears to be which one of those 4 standard jack colors is connected to which one of your 6 non-standard colors. Sounding them out is the logical course of action as already recommended by others.
Or, if you can locate the junction box outside your house where the incoming line from your local telco terminates, perhaps you can see the scheme used from there into your home by sounding them out.
End Grain is offline   Reply With Quote
Old 12-14-2007, 01:42 PM   #8
3 Pair non-bell wire (ie Cat-3) will have the pairs as described by the other person.
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
Electrical outlet phone jack extension? mikehende Electrical 3 11-28-2007 08:05 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-17-2007 11:46 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
