Phone Jack Wiring - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-18-2008, 10:57 AM   #1
phone jack wiring
I am trying to get a phone line in my upstairs working. I am not sure if it ever worked though. is there any way i can tell if it works. The wire comes out of the wall and the wires are bare. how do i tell if it works? i don't have a volt meter eigther. can someone help?
JAVAMAN is offline   Reply With Quote
Old 03-18-2008, 02:39 PM   #2
joed's Avatar
Rewards Points: 12,010
You could could measure the voltage on in the two wire. If you get about 40 VDC then it is probably good.
OR
Put a jack on it and plug in a phone. See if you get dial tone.
Old 03-18-2008, 02:44 PM   #3
how do i put ajack on it. the wore comming out of the wall has six wires and none of them are red black green or yellow.
Old 03-18-2008, 03:20 PM   #4
find the junction at the other end and you can see how it's hooked up.(in basement or outside)
johnrem is offline   Reply With Quote
Old 03-18-2008, 04:12 PM   #5
Do you have a blue and blue/white?
jerryh3 is offline   Reply With Quote
Old 03-18-2008, 04:20 PM   #6
Yes I Believe That I Do. Its A Orange White/orange Blue Blue/white And Green Green/white
Old 03-18-2008, 04:53 PM   #7
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
No BROWN BROWN/WHITE? (probably Cat3, and they don't make those anymore, but you can wire a Cat5 jack to it) There is no red, black, yellow designation to keep voice seperate from power, even though phone has voltage.
Yes, find the box and see what you have. Post a picture if you can.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 03-18-2008, 05:19 PM   #8
Yeah, the easiest way is to find the demarcation point(usually a gray box outside of the house) and see how it wired. This links explains the RJ11 standard pretty well:
http://en.wikipedia.org/wiki/RJ11%2C_RJ14%2C_RJ25
phone wiring Potomac101 Electrical 8 02-11-2008 04:23 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
Electrical outlet phone jack extension? mikehende Electrical 3 11-28-2007 09:05 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-18-2007 12:46 AM
Installation of new phone jack alvanos Electrical 4 04-05-2006 07:12 PM
