PEX Fittings Leaking - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 03:50 PM   #1
We have been in our house for a little over 11 years. Within the last year or so we have had 4 separate plumbing leaks - all at the PEX fittings. Has anyone had this problem?
Lulabelle2 is offline   Reply With Quote
Old 01-27-2011, 03:58 PM   #2
Rewards Points: 5,336
If you fittings are made by Zurn, they have had issues with fittings made a few years ago. Do a web search and compare the time frame and your fittings.
There should be a name on the fittings you have.
Ron
Old 01-27-2011, 04:12 PM   #3
Thanks! As soon as hubby gets home from work he will be fixing our latest leak. I'll be sure to check the name on the fitting!
Old 01-28-2011, 10:58 AM   #4
Rewards Points: 3,130
I don't know details, but there was at least one class-action lawsuit against Zurn for leaking fittings.
Old 01-28-2011, 11:34 AM   #5
It could also be a simple issue of the fittings being put on incorrectly. Once the OP comes back with some more info and maybe some pictures of the fittings we can go from there.
Ron
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 08:47 AM
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 07:33 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
