I think since this site is a DIY site, why not solve the world's energy problem and let's get together and create a perpetual motion machine? I have an idea that may just work, but I need someone good at numbers to see if it'd be worth the trouble of building the prototype. (Willie T? wanna challenge? Nestor Kelebay? Want to unretire?)
I've done sketches and I see no reason why my design won't work.
No fuel burned, no electricity needed, etc. So.... anyone want to play?
Some physicists have remarked that Faraday's law is a single equation describing two different phenomena: The motional EMF generated by a magnetic force on a moving wire, and the transformer EMF generated by an electric force due to a changing magnetic field
If you pass a moving wire (a conductor) through an magnetic field, it will produce an EMF (induce a voltage) into the wire or inversely, if you pass an electromagnetic field across a conductor, it will produce an EMF (induce a voltage) into the conductor.
You need 3 things to induce an EMF
1. a magnetic field
2. a conductor
3. relative motion between them (numbers 1 and 2)
and to take that a little further, this is the basis for all AC transformers . The AC current is what causes the relative movement. By the current alternating flow direction, it causes an electromagnetic field to be produced. That field, as it grows and collapses (as the AC reverses direction) will move passed the wires of the secondary of the transformer and induce a voltage into those conductors (EMF)
What DM is speaking about doing is using the slave labor (i.e. child) to produce the relative motion, a magnet to produce the original magnetic field, and a winding of wire as the secondary conductor which will then ultimately be connected to a battery of some type to store the energy.
basically kinetic energy creates an electromagnetic field which generates electricity that is stored in a battery or transferred to a device and stored?
Another thought is using the playground equipment itself as collectors. swings that store power, teeter-totters, etc.
I doubt THAT would violate any "child labor" laws... lol (but ya never know... there are some real nuts out there!)
but there, you're still over-involving the kids.... someone would bytch...
I was thinking more towards the top of the chains. magnetics, or even 'spring-winding' could be achieved "out of reach". Faraday tubes under the teeter-totters?
*BINGO!* Now we're talking! Funny thing, when I saw the slides in the background, all I could think of was the kids with magnets on them, getting off the swings and then trying to slide, but their butts are magnetized, so they just sit there.... LOL
or stuck upside-down to the monkey bars... their little legs flailing in the air crying "TEACHER! TEACHER! HELP!"
My deduction? Magnets attached to kids in a mostly steel playground = maybe not so good of an idea...
applying this to playground equipment shouldnt be too hard, although you will have lots of angry people with too much free time complaining about the electromagnetic radiation that it is affecting their kids (while they feed them mcdonalds and soda all day everyday.)
if you really got industrious you could apply it to door swing mechanisms, windows, even shoes - although the energy received per action would be pretty low.
What do 3 x BEV (battery electric vehicles) rated at 445kw each, 2 x 8MW generators have in common or actually have to do with each other?
3 X 445 = 1335. YES 2 X 8000 = 16,000. YES 16000 - 1335 = 14, 665 yes.
So what can be applied or created to meet this equation?
I think I have a theoretical application which does not play or question the laws of physics cause and effect, action and reaction.
want to play?
I saw something similar to your suggestion a few years back on discovery channel where the round about at a school was encouraged to be used by the pupils that had a generator attached to the rotating shaft and the power created was used for the computers in a classroom. I think this was in Uganda. Ingenius, simple and effective plus the pupils got a bit of fun in the mix
Edgar Cayce said we would have free energy devices in our garages, about the size of a water heater. He said it would have something like a grounding rod outside our homes and it would have some kind of dipole (T or U shaped thing) at the top.
And Tesla invented something similar with his Wardenclyffe Tower in New Jersey. Supposedly it generated energy from 'space' and it was transmitted through the ground. He said that he had 20 or so appliances set around the site that used wireless antennae to power them. And he said that the energy developed was so great that the building started to crack and items in the building began to fly and float through the building. He said he had to cut it off, but not before someone called the police and when they arrived Tesla said it was an earthquake. Unfortunately, it was financed by J P Morgan and he cut the purse strings and made him tear it down.
And Leedskalnin (Coral Castle in Florida) supposedly found the secret to free energy as well. He did not move those 50 ton blocks of coral by himself. He said that one secret was moving the blocks of coral at night. He said that something changed in the atmosphere at night that did not exist during the day.
And......one common denominator between Coral Castle and the Pyramids was the use of pink granite or pink coral.
I am a hundred percent convinced that it has already been discovered and it has been patented using obscure language. But, international politics is well entrenched in oil and the dollar would decline in value if it was not needed to buy oil. Just think of all the nations in the world whose economies are dependent on oil. And the problems that would exist if they lost that revenue.
"Control oil or the money supply and you control Nations."
"Control the food supply and you control people."
I have also read a few times that the same science that explains free energy is the same science that creates levitation ( flying saucers?), so that might have some national defense issues.
But, I definitely think that it already exists, but the people behind the curtains are more powerful than the people inventing it. And that is why a lot of the people researching it have died prematurely. It's not a conspiracy, it's all documented.
Anyhow, that is my rant on free energy.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
