Permits And Reassessing/Reappraisal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 11:00 PM   #1
Permits and Reassessing/Reappraisal
I will be upgrading the old wiring in my house. I know I need an electrical permit to do this. Do I also need building permit for tearing down drywall in order to get to the electrical wiring? (This is in san francisco).
Also, will doing this require reappraisal? On the assessors office website, it states: "If the construction is new (such as a room addition), a reappraisal is required. If the construction is for replacement, repair, or maintenance, a reappraisal is not required." I'm not sure what constitutes an new addition. I have a 2 rooms in the basement that was not permitted when I purchased it. Since I am basically tearing down to the studs to rewire, and I want it permitted, does that now count as a new addition?
thanks in advance.
acerunner is offline   Reply With Quote
Old 02-23-2010, 11:03 PM   #2
If it was not permitted/inspected before then legally you need it permitted & inspected now
Old 02-24-2010, 04:12 AM   #3
yes, i understand that. I want everything done right and permitted, which is all going to be part of the renovations. My question is, does this fall under the catergory of remodeling existing structure, or is it considered an addition?
I'm pretty handy when it comes to building/fixing things, but documents & paperwork is always a nightmare.
Old 02-24-2010, 06:55 AM   #4
Different localities define this differently. Around here, the only thing that adds to the appraisal is a major upgrade or addition. Wiring is condsidered maintenance, a complete bathroom or kitchen redo might not be.
Old 02-24-2010, 08:17 AM   #5
Basement rooms need to be inspected & permitted to be considered living space
Only your local Building Dept can answer your question on what they require
Old 02-24-2010, 12:23 PM   #6
Rewards Points: 1,016
Typically only adding to the square footage of the footprint of the house can trigger a reappraisal - YMMY, depending on your locale - check with your building department.
Old 02-24-2010, 10:13 PM   #7
Registered User
Termite's Avatar
Without seriously expanding or remodeling a large portion of the home, I doubt you'll get any interest from the appraiser's office at all. They don't have any idea of the condition of the interior of your home other than maybe knowing the bathroom and bedroom counts and total square footage.
Old 02-24-2010, 10:16 PM   #8
Question
But (probably) no reassessment! (Hopefully)!
spark plug is offline   Reply With Quote
Old 02-26-2010, 05:37 PM   #9
Thumbs up
Permits & Etc.
My advice is to have the electral work performed by someone qualified, which might be yourself. Most areas require a licensed electrician. In either case you should be able to do the sheetrock yourself. If this qualified person doesn't insist you get a permit you may be able to save a few dollars.
NY Jim
NY Jim is offline   Reply With Quote
Do I really need permits? mirzai_m Building & Construction 20 01-09-2014 02:21 PM
Permits Red Truck General DIY Discussions 14 02-18-2010 11:33 AM
permits / inspections evill Building & Construction 18 11-29-2009 09:27 PM
Please advise: buying a house without permits? istari General DIY Discussions 8 07-16-2008 11:18 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
