Perhaps A Timely Insulation Reminder - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 11:07 AM   #1
Rewards Points: 24
Perhaps a timely insulation reminder
I had just walked back up to the house this morning, for a second cup of coffee, when the phone rang. Neighbor has a roof leak. Great; 20 degrees here this morning, with a fresh light coating of snow, so where else would I want to be than on a roof?!?! So, he shows me a wall with a bathroom on each side, and water literally running down both sides. We walk outside, and sure enough, the vent stack is right where the leak is. Well, it looks okay at a distance, so let's look in the attic. Hmmm, no evidence of a flashing leak, but what's this? The insulation was all rolled out nice and straight, but I could shine my light through the gaps around the vent stack into the wall cavity. Pack the insulation around the pipe, and head back down. Put my infrared thermometer on the wall, and as I expected, a 15-20 degree drop in that particular cavity. A cup of coffee and some idle chat later, the differential was decreasing, so his assignment for this afternoon is to pick up a can of red Great Stuff, and head back up to the attic.
The Following User Says Thank You to DexterII For This Useful Post:
oh'mike (12-10-2011)
Old 12-10-2011, 11:13 AM   #2
A Little Of Everything
Rewards Points: 1,362
Yep. Lots and lots of problems - big and small - "show up" in early winter.
DrHicks is online now   Reply With Quote
Old 12-10-2011, 11:28 AM   #3
Rewards Points: 6,652
Tell him instead of Great Stuff, use Dap foam in the can. Also while he is at it, tell him to foam around outside wall outlets, and up in the attic around lights, wiring, and vent pipes, and maybe check around windows & doors for air leaks. He will find that it will stop the chimney effect. It took me about two cans to do around our windows and the outlets.
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 06:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
