Penetrating Damp From Derelict Neighbour! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-28-2008, 01:20 AM   #1
Question
Penetrating damp from derelict neighbour!
hi, i have a problem with my property. my neighbouring terraced house is derelict, with a little amount of roof, lots of weeds and a whole load of water/ rain coming in. as you can guess i thus have a damp problem!
i can get into the house, as its been derelict for 15years. so i was thinking of spraying the party wall with a silicone based product to seal the water on the neighbours side.
or external render it?
any ideas, help or advice would be great.
tenants are moving out, new tenants have walked away, the council knows and has supposedly started the legal mumbo jumbo, but i cant wait anymore.
my house is getting very bad!
thanks mark
ps.would a thick black membrane work? how wouldi seal the top & sides from rain etc? would i have to treat the wall? wouldnt this method force all remaining damp back through my house but stop it in the long run?
markslostmarbles is offline   Reply With Quote
Old 08-28-2008, 01:41 PM   #2
Registered User
Termite's Avatar
From your description, it sounds like you share a common "party" wall with the neighboring house, and that wall is degrading due to water infiltration in the neighboring house.
Can you tell us if the wall is wood framing covered in gypsum wallboard, or is it block?
If it is block, you will have more options. If it is framed, you're in trouble.
Old 08-28-2008, 02:40 PM   #3
-old block wall, not boarded.
-neighbours side is ruined, exposed brick, damged mortar beds etc.
thanks.
Old 08-28-2008, 03:36 PM   #4
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Question
Pictures
Pictures would really help. Very hard to know exactly what you have with out seeing something.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 08-28-2008, 04:17 PM   #5
Registered User
Termite's Avatar
You could paint a moisture sealant like DryLok on your side of the wall to prevent moisture from actually penetrating into your unit. But, the problem is that the wall itself will continue to degrade until the moisture is prevented from penetrating it. I don't know what you could apply to it to prevent water from coming through, but there is probably something. If nothing else, it might help to hang a weatherproof membrane in there where the roof leaks against the wall (plastic or felt paper for instance).
I'd be concerned about the legal ramifications of going in an modifying the neighboring property in any way. There's a chance that you could be held falsely liable for further degradation of the wall.
Old 08-28-2008, 04:57 PM   #6
prooving it was me would be impossible. the owner hasnt been in his own house for 15 years, its bricked up, so no ventilation too!
i think cover roof, membrane his wall, dehumidfier into my house, render/patch & paint.
should be job done i hope.
what you think?
Old 08-28-2008, 05:15 PM   #7
Registered User
Termite's Avatar
None of those things could hurt...And will probably improve the situation you've got right now!
Old 08-29-2008, 01:05 AM   #8
thanks thekctermite. your advice is gratefully received.
mark
Old 08-30-2008, 01:12 PM   #9
deleted
gatorate is offline   Reply With Quote
Old 08-30-2008, 07:45 PM   #10
Rewards Points: 258
How about a 4mil plastic tarp along the length of the wall. Tack it to the ceiling and extend it out 3 or 4 ft at the floor and sidewalls. That should keep the bulk of the water off the wall.
Less invasive and easily undone.
Just a thought.
Docfletcher is offline   Reply With Quote
Old 09-02-2008, 12:46 PM   #11
Rewards Points: 562
BUY the place for little of nothing and have control over the situation!!
4just1don is offline   Reply With Quote
Old 09-04-2008, 05:15 PM   #12
Advice worth 2 cents!
Rewards Points: 150
That's what I call "think outside the bun"
---pete
HandyPete is offline   Reply With Quote
Old 09-04-2008, 05:51 PM   #13
yeh, way out of the bun! you havnt seen the property or the area, more work than worth it!
Tags
damp , derelict , mould , penetrating , seal
Damp, Crumbling bricks & Blown Plaster crscrs Building & Construction 2 10-02-2008 05:20 PM
Did the bush cause the damp? atomicpig General DIY Discussions 9 02-13-2007 07:00 PM
