We installed 11 new custom Pella Casement windows in our home in 2001. As time passed, they started having issues closing. We would have to crank them building speed to get them into the frame. Crank slow, as recommended, at they would not pull into the frame because they "hung heavy" in the frame and warped. If the window was a double window, I could open the one next to the one that wouldn't close and push it closed from the outside but if it was a single unit, it would not latch.
We called Pella Corporate to discuss the problem. They told me "The casement windows can't be left open for long. The wind and weather reaks havoc on the frame." I replied, that they won't close after being left open over night, no wind, no rain, no inclement weather". They repeated what they said the first time.
So, the bottom line is that Pella sells a window design that they know has issues and they have no excuse for why they haven't fixed the problem. A larger window requires a more supportive bracket and cranking system and they choose not to make the advancements to their product line.
It's on to The Better Business Bureau, forums like this one and word of mouth.
I have one Pella clad casement that I put in a year and a half ago as an experiment.
One of the drawbacks to a casment is if there is rain while the window is open it obviously gets the window frame wet. But that shouldnt be an issue in your case where the window was just open and no rain.
I havent had the issues you are having with the opening/closing which is fine in my case. I do have a moisture build up on the bottom of the window on colder mornings which I have yet to resolve.
Looking at doing a few more windows in the futue and its questionable if it will be the Pella brand.
You're right about the rain problems. That's how I'm sure the weather played no part. And, it's not just one window. It's 6 of the larger ones (wider than 12" opening). I'm sure it's the hardware that can't support the weight of the window when open.
We also had rain water come in through the top framing screws because the Pella installers neglected to install drip edges on the top frames of the 2 largest picture windows. We also had frost on the wall below 2 other windows because they also neglected to insulate. We called them back and they fixed the issues after some cohersing but I had to stand over them to be sure it was done correctly. So much for a "Pella Professional Installation".
If you have forced air heat, you probably have a humidifier. If you do, set the humidistat to a lower number and the moisture on the lower part of the window will probably go away. We had the same problem the first winter we had them installed and that solved it.
If I am satisfied with Pella at all, it's solely because when they do close, they are tight!
I wish we had these forums back when I bought our windoes. If I knew the problem existed before I bought them....
Casements were the only design we could go with on our contemporary home. The ones that were in the home were 20 year old Andersens. I don't know why I didn't go to them for a quote. Pella just "seemed" to have a better act, I guess.
Sorry, but this sounds more like an installation issue than a product quality issue. Your statements about the installers indicate to me that these guys are not top notch craftsmen...It is unfortunate that they are a Pella installation outfit, but that is nothing more than good marketing.
I have no dog in this fight, and no reason to defend Pella products. Titleing the thread "Don't buy Pella casement windows" is unproductive and generally misleading. Not sure which casement you bought, but most Pellas around here are "builder grade" windows....With windows and window installers, there's a direct correlation between price and performance.
If I were being subjective or had any doubts, I would agree with you. I'm not just the HO. I am a contractor myself. I don't install windows but it's not difficult to understand the problem.
The casements we bought were the top-of-the-line Architect series windows, most were custom sizes. The Pella distributor in our area was the only Pella distributor recommended by Pella corp at the time and were strongly recommended for installation to maintain the warranty.
We recently broke 2 unison lock assemblies while running the windows in to attempt to have the hooks grab the window and pull them closed. The Pella service tech who came out to fix the lock assemblies knew of the problem and was the one who told me there was no real fix for it and recommended that I should contact Pella corporate, write letters, etc... They haven't called back.
The windows we bought that are 15" width or less have no problem. Once they get over that dim, the window hangs heavy and can't be left open for "too long" or the outter edge droops then doesn't pull in when cranking closed. This is not installation, it's hardware design.
i don't think that this is a problem exclusive to Pella. I bought 2 6'x6' Crestline double casements NEW for $100.00 each! (wrong size returns, $860 EACH if installed, i got them clearance after they sat for 3 years) after installing i foresaw the problems you are describing, i.e. the 'difficult to close' thing. at first i told the wife and kids that they should not attempt to close them. i should be the only one. that worked ok, but i added these wooden beads (predrill the holes!) close to center on the windows to serve as a 'pull' and now there is no problem. an afterthought... small flushmount drawer handles would probably would have been better. i'll probably swap them out soon. again, SLOWLY AND CAREFULLY predrill!
Thanks for the idea and, yup, we paid almost $900. per double window for 6 sets (not including the other 5 sets) and the screen is on the inside so: 1) I'm not retro-fitting anything to make it work and 2) The screen precludes it anyway. But thanks again!
New and first post. I am retired from the school dist. now. We had Pella casement windows in a few of our schools and had the same problems. We had a guy come out from Pella, he showed us a little trick, You take a small hammer wedge and lift the window and put the wedge under the lower hindge and it lifts it right up and levels the window. It worked perfect. I can't remember how it was slipped in there, but in only took about 5 seconds to do it.
I hope it's okay to post this woman's name and address here. If the mod's. have to delete it, you can PM me and I'll give her info to you.
Elaine Sagers
Vice President of Customer Satisfaction
PELLA CORPORATION
Pella, Iowa 50219
Send a letter off to her. I had a few issues with my Pella slider door. I called them and really didn't get the help I needed or expected. I don't remember how I got this woman's name, but I sent her a letter via snail mail. Someone from Pella called me back and they were very helpful.
We also had a long crack in a newer Pella window downstairs (probably caused by someone here) and I called Pella to ask about a replacement. They didn't ask any questions and sent a new window within a week. Free.
After reading what you've posted about your experience though, I would think twice before I buy their casement windows. They should stand behind their gaurantee for you.
They told me "The casement windows can't be left open for long."
WHAT!? Imagine having a problem with your car or truck. If you called Ford or GM, would they ever tell you, "That model of truck can't be driven for long."? That's probably not a good example, because you just might get that response some day if you drive an electric car :laughing:.
Good luck, I hope you get to the right person at Pella and get the help you need.
Just keep after them and if they don't come up with a satisfactory solution, then ask for your money back or tell them you will be contacting an attorney to exercise your rights.
I, as a former customer was not satisfied with their installation practices. Some of their work was corrected by me. The district manager called me pickey. They installed a bay window and front door. Both had issues.
1. They left air gaps around the framing even after installing expanding foam on the bay frameand door frame.
2. Exterior caulking also left air gaps.
3. Underneath the bay, a nail was doubled over. It should have been pulled and driven in another location.
4. Because of the weight of the window extending out away from the wall, I told them I wanted supports placed under the bay. The installer drilled into the brick to place the supports, instead of the mortor joint as this joint has about 1/4 inch spacing and would be the logical place to install an anchor and lagscrews. My brickface has hollow spaces in it. The installer should have known this. It looked sloppy afterwards. I made them come back and cover the supports with aluminum trim to dress it up.
Aside from having a defective product as you have; Pella does not do a good job in determining the skills of their installers.
In my opinion, I would avoid using Pella. I've experienced many problems with my Pella Architect Series windows and doors, including cladding problems, seal failure, spotting on the glass, rotting wood among other issues. These Pella windows and doors were installed throughout my house in 1995. You can view photos of the Pella window and door defects/failures in my home at onlinelitigationdiscovery.com. Pella refuses to acknowledge these claims. Therefore, I highly discourage using this brand.
I'm very interested in hearing other people's experiences regarding problems with your Pella windows. If you, or someone you know, has had similar problems with Pella, please go to my website (onlinelitigationdiscovery.com) and tell me your similar experience. Thank you for your time! -A. Bailey
I like the Andersens I have. They were installed in 1990 and the only issues I've ever had is if they are opened too far, they are difficult to crank back shut till you get past that too far point. Easily remedied, just don't over crank open.
Also watch out for the "Wanna Be" contractors. Get it in your contract that the distributor has to take responsibility for his hires that do sloopy work and the customer can demand that they install it correctly. Especially when after they spray foam into the gaps around windows and doors. Tell the worker not to add any trim around windows or doors until the foam has stopped expanding. Then they must check their work for any remaining air gaps and add more foam if necessary. The contractor did not do this and I ended up doing it myself because I do not want a "Wanna Be" doing repair work. Sadly, the Pella organization is nothing more then a bunch of white shirts that know nothing about good installation practices. So when they hire for their installations, they do not distinquish between good contractors and the "Wanna Be's.
Here's an update;
We've still had issues with the windows. We've had 'service' out 3 times to install a shim that keeps the windows aligned enough to close if they've been open for more than a day.
Then I found a recall for our exact windows that was issued for '05 or later windows for faulty window support allowing the window to fall out of the frame. Ours are from '01.
I had just caught my finger (large blood blister under the nail...ouch!) in the window trying to assist in it's closing so that gave me some incentive. I contacted the U.S. Consumer Product Safety Commission. They came out, investigated the windows and took all the history.
We installed Pella casement Windows (some are double casement) Pro Series throughout our home from 2000-2003 as we remodeled and have had none of the problems the first post mentions. Will the casement windows get hard to crank after time? OF COURSE they will,they get dirt,bugs etc around the crank and slide from being open. These do need to be cleaned yearly. I get several rags,water Windex what ever,open the window and thoroughly clean the crank and the sliding mechanism and channel it slides on. These clean up to look brand new. Then spray them lightly with WD40 and crank them a few times. They close BETTER than when they were new.
We have had zero warping that's described. If so I find it hard to believe that Pella would just blow you off unless they could prove it was a bad install. We have Pella sliding doors,casements,double casements and one double hung window--some are now ten years old,work perfect and look new. If I had to do it again I'd buy Pella windows once again.
Believe what you like. To this day we get the same answer, you can't leave them open for "long" or they will warp in the frame. You bought the Pro Series, a lighter framed window.
I'm working with the Consumer Product Safety Board about our problem.
Pella doesn't have any more problems than any other brand. I'll be the first to admit that their customer service stinks, as when there are issues, they pretty much tell you to get bent and refuse to acknowledge that there is any problem. That being said, that is why the installation company that you choose is so important. Pella itself manufactures windows, it does not install them. They have a licensed dealer network, certified installer program, etc., however every installation that is done is by an independant company who MUST be held accountable. Pella's old casement design did not allow for adjustment if the sash started sagging, which they've since corrected. However, even the old models had a pretty easy fix in that you could shim the hardware and get it working like a champ. Many if not all of the complaints in this thread could've been addressed by competent installer. (other than the poor customer service of course). It unfair to say such a generalized statement like "do not buy their products".... How about something like "Pella's customer service is terrible!" ...I'd agree with that!
Pella certified installer and distributor. We've had the 'shim' installed twice in some and three times in others of our windows. It lasts about two years then...saaaagggg..then service call and a $95 charge to re-install. I stand behind my statement that their service response is the worst and the product, Architectural Casement windows that are larger than 18" wide, sag when left open over night and they admit it! They just don't say it until they're installed.
Their newer products have a built in adjuster just like EVERY other casment window. Sagging is a problem inherent with casements, especially larger ones. Again, it is a problem that can be fixed by a competent installer. Perhaps they are using wood shims which will compress over time and lead to the same problem. I recommend aluminum, or at least a composite... i think you missed my point on the certified installers. I'm not saying that it guarantees a good installation, in fact what I'm saying is that it doesn't mean a heck of a lot. You need to choose a good installation company regardless of whether they are certified by Pella. I've installed a lot of Pella products over the years and I am not a certified dealer, however I'm pretty sure that I've correctly identified your problem and given the solution. How do I know? ...because it's a common issue and I've taken care of it many times and when my company does it, there is no charge.... Why can't the beancounters at the manufacturer figure it out? I don't know, maybe they just don't care. Like I said, you'll never find me defending their customer service department.
So...take them to court with all your receipts and get a settlement. Make them show or prove in court that they told you before you installed them that they would sag if left open. In the spring and fall some of ours are left open for days at a time and again no problems.
We purchased 52 Pella Architect double hung Douglas fir windows for our house in August 2009. These windows were installed for only days and we had our first snow. We had snow inside our house that came in where the 2 sills meet. Pella came to our house and replaced nearly all the windows. They got upset when, after replacing all the units except 21, they saw that the new units were also going to leak. The Pella staff then left the last 21 units stacked in our garage and left. Pella will not talk to us either on the phone, in person or via email. We now have rain and mold that has penetrated our home under those windows all through our home. Our home is just sitting, unfinished. We live in Moravia; Iowa just 40 minutes from Pella Iowa where the factory is that makes these products. We have tried to talk to staff at Pella and they will not see us. We just do not know what to do. We also have since found out that the product we were sold and paid for is not Douglas Fir at all. Pella hides the low quality pine on the inside of the window. They put a thin coat of veneer on the outside, where all can see and think that we received the product that we ordered and paid for. We strongly suggest that you not deal with Pella. This company is dishonest through and through. We are Christians and have put off this action for months, but we do not have a home and do not have any other options as Pella won't even return our calls or emails. Thank you for the time you take on behalf of this action.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
