Paving Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 3 Post By joed
  • 2 Post By stick\shift
Old 12-28-2016, 04:50 PM   #1
Rewards Points: 6
Paving Question
How much would you say is fair to dig a trench in a driveway, laying 2 inch conduit or pipe and refilling with asphalt? Dimensions would be about 1 foot wide, 20 feet long and 1 foot deep.
mci_it is offline   Reply With Quote
Old 12-28-2016, 05:47 PM   #2
Rewards Points: 13,276
Re: Paving Question
How much what?
Money?
This can be done without cutting the driveway.
Old 12-28-2016, 05:50 PM   #3
Rewards Points: 6
Re: Paving Question
Well I'm really asking what a company would charge to do this type of project.
Old 12-28-2016, 06:02 PM   #4
joed's Avatar
Rewards Points: 12,000
Re: Paving Question
I would guess that the asphalt alone is about 700-800. So I would WAG $2000.
Old 12-28-2016, 06:32 PM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Re: Paving Question
Pricing questions are frowned upon here because there are so many factors involved.
Besides, this is a DIY site, and that's a pretty easy diy project. You could rent a pavement cutter and dig the trench by hand pretty easily. It'd be a helluva lot cheaper than hiring someone to do it.
I hate signatures.
Mort is online now   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
jomama45 (12-29-2016)
Old 12-28-2016, 07:25 PM   #6
Rewards Points: 6
Re: Paving Question
Well I went to the contractor forum and they told me to go here. I'm not asking this for myself to be honest.
Old 12-28-2016, 07:50 PM   #7
joed's Avatar
Re: Paving Question
Best to get some local estimates.
Bondo, GrayHair and Mrbuilder like this.
Old 12-28-2016, 08:07 PM   #8
GrayHair's Avatar
Rewards Points: 950
Re: Paving Question
Please note that the minimum burial depth for electrical conduit "Under streets, highways, roads, alleys, driveways, and parking lots" is 24 inches. [[Table 300.5, National Electrical Code, 2008]]
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is online now   Reply With Quote
Old 12-29-2016, 11:07 AM   #9
Rewards Points: 504
Re: Paving Question
Too many variables to estimate remotely. Best practice is to get at least three local bids so you can compare and ask questions.
stick\shift is offline   Reply With Quote
Old 12-29-2016, 02:29 PM   #10
Rewards Points: 744
Re: Paving Question
the 'move-on' charge would cost more than the trench itself. Do you have a small equipment rental place near you?
KPDMinc is online now   Reply With Quote
Old 12-29-2016, 02:31 PM   #11
Rewards Points: 744
Re: Paving Question
thats not even one CY.... 700-800 is a pretty high est.
Old 12-29-2016, 02:33 PM   #12
Rewards Points: 744
Re: Paving Question
he never said what the 2" conduit is for. could be running low voltage wiring, or a chase for irrigation... I agree, 24" would be better in the end...
Old 12-29-2016, 03:46 PM   #13
GrayHair's Avatar
Rewards Points: 950
Re: Paving Question
Use not being stated is why I wrote electrical. I found that where a liquid was involved, most people said pipe, even if they had tubing. So his use of the term conduit made me lean toward electrical or low voltage. When up against unknowns, I found it safer to follow the most restrictive path. While it's irritating to do too much, it's also supremely unwise to do too little.
Old 12-29-2016, 06:24 PM   #14
Mort's Avatar
Rewards Points: 690
Re: Paving Question
If you could even get a crew out to just do that small of a job without piggybacking on another job in the area, it's gonna be expensive.
I hate signatures.
Old 12-29-2016, 06:35 PM   #15
Rewards Points: 744
Re: Paving Question
thats what I mentioned in #10
Tags
asphalt , paving
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 09:11 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
