Pavers - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 05:26 PM   #1
pavers
What would help to keep sand and pea gravel from washing out between pavers and driveway?
butchmcd is offline   Reply With Quote
Old 08-16-2009, 05:41 PM   #2
Old School
Willie T's Avatar
You might want to look into Ecofil or similar products.
Willie T
Old 08-16-2009, 05:45 PM   #3
Whst ecofil?
Old 08-16-2009, 09:50 PM   #4
Concrete & Masonry
Rewards Points: 548
What you should look into is either polymeric sand or at least a sealer that will help retain what you currently have. You may need to get these things from a masonry supply center.
jomama45 is offline   Reply With Quote
Old 08-19-2009, 11:01 AM   #5
Sealer is the best
I just learned how to install pavers, I did a very large area and it came out perfect. When I checked with the pros about the same problem you described I recieved two options:
1) Mix some portland cement with the sand when you sweep it into the gaps, once you hose off the surface it will harden and help hold the sand in place. The only problem with this option is sometimes it will dis-color the pavers.
2) A good sealer applied after the surface has been cleaned and dried will help hold the sand. A second and third coat will make it last a long while.
I found videos and a lot of helpful info about pavers ( installing and maintaining them) on a site called LINK REMOVED there was info on a few other sites but this was the most complete I have found.
joeys509 is offline   Reply With Quote
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 05:45 PM
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 08:59 PM
How to get Mortar film on pavers? Tonya36 Landscaping & Lawn Care 1 06-15-2009 05:32 PM
landscaping backyard with Pavers - needs concrete base? sundar Landscaping & Lawn Care 7 10-09-2008 07:28 PM
Brick pavers on driveway ???? sflamedic General DIY Discussions 2 04-21-2008 11:12 AM
