Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-22-2010, 02:19 PM   #1
Metalman
Patio door
Can anyone tell me how to replace the rollers on the bottom of the sliding door? I tried to lift the door out over the inner rail, but it wouldn't go that far up. Then I looked about taking the stationary glass out, but there are no screws to do that. What up, dude?
dave1123 is offline   Reply With Quote
Old 08-22-2010, 03:41 PM   #2
Patio door
dave, not sure of your brand. never seen one that couldn't come out. you may have o remove caps at lower edge and raise the wheel adjustments to clear the threshold ledge for lifting out. then the wheel assy's are just pressure fit in usually, grab and pull.
TimPa is offline   Reply With Quote
Old 08-22-2010, 05:37 PM   #3
jlhaslip's Avatar
Patio door
are there any adjustments on the top of the door frame?
might need to use a screwdriver or chisel to coax the wheels over the track.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 08-22-2010, 05:44 PM   #4
Moderator
Patio door
Slide the door to the open position to clear the security blocks above, then lift after raising wheels, as mentioned already. I've installed some that needed a flat bar to get over the bottom frame.......
Be safe, Gary
Clothes taking longer to dry?
Old 08-22-2010, 06:38 PM   #5
Moderator
kwikfishron's Avatar
Patio door
On the stubborn ones I take a thin piece on metal (a flashing scrap) and lift the door and slide the thin metal under the roller. It hasn’t failed me yet.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 08-23-2010, 05:20 AM   #6
Metalman
Patio door
Thank you, gentlemen! I just didn't know how much brute force was needed. These wheels ride on a raised track in the center of the width of the door and have a phillips head screw to secure them. This door came with the house and never closed tightly from top to bottom. I adjusted the one roller up enough to disengage the adjusting screw and it went all the way down. I think if I can get it back together, I can lower the other one enough to get it to seal. I assumed that the screw would start getting tight near the end of it's limit, but it didn't. It was made about 1965 and I haven't a clue who made it. I will try a few things and get back to you. Thanks again for your help. This website and you guys are A#1
Old 09-14-2010, 02:09 AM   #7
Metalman
Patio door
My problem with the patio door was the threshold plate was not securely fastened to the floor and wouldn't allow the door to clear. I drilled the plate and installed 5 galvanized deck screws and the door came right out. Thanks again for kick-starting my brain!
Metalman
patio door installation question gintaras Building & Construction 3 01-20-2010 11:32 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
Replacing windows with sliding patio door, should I match widths? TomServo Building & Construction 5 09-21-2009 08:22 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
