Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-20-2011, 09:48 PM   #1
ACY
Patching very large access cavity
Added plumbing to the closet next to our bathroom in the high-rise we live in but now I have to deal with making it all look pretty. This is interior wall that has to clean up nice so just slapping a piece of drywall over it won’t cut it. I don’t think I’ll ever access the space again so semi permanent solution is fine. The current construction is old fire block wall and expanded metal lath. I’ve had some thought to just cover with more lath and plaster but that’s pretty complicated. So if you have ideas or suggestion it would be greatly appreciated. I’ve ready so much stuff online about different plasters, cements etc. My head is just spinning and I cant keep it all straight!
ACY is offline   Reply With Quote
Old 10-21-2011, 08:23 AM   #2
Square it off and either sheetrock or plaster it.
It's a wall, what else would you do with it?
Ron
B. Franklin 1759
Old 10-21-2011, 08:36 AM   #3
ACY
Well I guess I'm a little puzzled bc the plaster over the lath and block is pretty thin, thinner then any piece of sheet rock. So if I do it this way the new sheet rock will sit past the old plaster
Old 10-21-2011, 10:08 AM   #4
You will need to prep the wall to recieve the sheetrock or plaster. That may include removing some of the wall to receive the sheetrock, adding blocking to screw the sheetrock into or adding protective metal covers so the pipes are protected.
You will need to do this whether you plaster it or sheetrock it.
The easy, no work option is a big vanity to cover the hole.
Ron
B. Franklin 1759
Old 10-22-2011, 07:48 AM   #5
ACY
Thank you guys, just wrapping up and all your suggestions came in handy. Thinking about it now it does seem like a pretty straightforward job but at the time with so many options available it was just a little too overwhelming.
Old 10-22-2011, 09:13 AM   #6
Considering the lack of studs, metal lath and plaster might be the easier route.
Why are there 2 drains coming out of the wall?
Ron
B. Franklin 1759
Old 10-22-2011, 09:48 AM   #7
ACY
The bottom one isn't a drain, it's piece of scrap to give the water supply line a little support.
I would have liked to do lath and plaster too as it would have been good learning experiences for all the mess and holes I'm going to be making in the ceiling in the very near future. oh well there'll be lots of practice for that later...holes just about done now anyway. Ready to starting plastering but can't start working till 10 am, building rules!
Old 10-24-2011, 09:37 AM   #8
Coconut Pete's paella!
CoconutPete's Avatar
Just our of curiosity: What room is this? I see a toilet. 1/2 bath, full bath? Is there a vanity in there? It seems like with that recessed space above the plumbing you could add a vanity and have a nice big deep medicine/stuff cabinet up there if you put a vanity there?
Hahaha. I was rapidly scrolling to the bottom to ask the same question after looking at the pics
CoconutPete is offline   Reply With Quote
Old 10-24-2011, 10:58 AM   #9
ACY
This is my one and only bathroom in my 1950's apartment (switched to co-ownership in the 70's). It is a full bath; the vanity slides right into that space and your right the original medicine cabinets were put right into the walls and as I move forward with my renovations I'll probably take advantage of that. The old owners put the cabinet over cavity and never took advantage of it! One slight issue is that this wall is parallel to the corridor behind it, there's only two rows of block and then plaster separating me form the corridor and noise is already a little bit of an issue!
I should post some more pics as slapped some drywall over the hole and plastered it and it came out pretty good. I was pretty pleased with my plumbing job! not bad for an amateur and saved me a lot of money. I had quotes from plumbers ranging from $300-500 for just the rough in. All in it cost me about $150. One scary thing I found out after the fact though is I might have exposed myself to asbestos. I'll never know for sure but the mortar and maybe the fire wall that I had to break into may have contained asbestos...no one knows for sure but this is the way everyone installs washer hookups in the building!
Old 10-24-2011, 11:06 AM   #10
OH! I was looking at it the wrong way. I thought the pics you posted were of the plumbing you had just added, but I now see that the new plumbing is to the left.
Well if your primary concern is noise and the vanity will cover the hole I'd say you've solved the problem.
Old 10-24-2011, 09:21 PM   #11
1. strap/support that water supply properly....lose the balancing act.
2. clean up all that metal lath
3. new metal lath over the entire area.
4. 3 or 4 coats of plaster, paint and done.
nothing is easier than plaster, whats the deal? (i guess sheetrock is easier, but that wont work here).
just go to your local store and pick up something like this
http://www.cemcosteel.com/ca-44.aspx
jcrack_corn is offline   Reply With Quote
knee wall attic access doors WillK Building & Construction 4 12-01-2010 07:32 AM
Access Door Panels For Tiled Fireplace Surround Fire4Effect Tiling, ceramics, marble 0 09-07-2010 02:12 PM
Access to ceiling joists in extension matskm Building & Construction 0 05-04-2010 08:27 AM
large mystery plywood panel in garage - any thoughts on this?! joeyboy General Discussion 15 12-02-2007 04:01 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
