Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-11-2012, 08:24 PM   #1
Patching asphalt driveway, so cal
I am patching an asphalt driveway which has been buckled in a few places by roots. Without knowing the best approach, I dug up one of the smaller areas and saw that the root came in from the side of the driveway and was less than a foot below the surface, but deeper than the asphalt layer. I dug up and cut out a 4ft section of 3-4" dia pine tree root. I wonder if is really necessary to remove the root or just cut it at the driveway edge? It would make patching the larger areas easier if I didn't have to dig up the root.
I have several bags of quikcrete cold patch. Should I be applying some type of sealer at the edge of my patch?
tns1 is offline   Reply With Quote
Old 02-11-2012, 08:31 PM   #2
Not going to work. Even if you cut off the root it's going to come back and do it again at some point.
But digging it all out cutting the root back at least 4 ft. and removing the old root, back filling with compatable fill and adding the patch will give you a few years.
Old 02-12-2012, 07:15 AM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Cold Patch is just that,... a temporary patch....
True Repairs are done with Hot-mix Asphalt...
Using Recycled Asphalt for Driveway? toddtx Building & Construction 2 07-17-2011 03:24 PM
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 12:50 PM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 04:42 PM
Spreading cement over asphalt driveway? Dagz Building & Construction 1 09-06-2010 08:55 PM
Patching holes in asphalt driveway joe3534 Landscaping & Lawn Care 5 11-22-2009 10:16 AM
