Painting Wooden Chair For Outdoor Use - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-23-2007, 09:35 AM   #1
Painting Wooden Chair for outdoor use
Painting a Wooden Chair for Outdoor Use
What would be the best type of paint. How to prepare.
The chair will be outside in climate of Jamaica.
Any help appreciated. Have never painted anything b4. Thanks.
Wanda
Wanda is offline   Reply With Quote
Old 08-23-2007, 08:48 PM   #2
fierysun's Avatar
When I painted over some oak chairs for outside this is what I did:
- cleaned the surfaces with a damp cloth
- used 120 grit sandpaper (from what I remember) to scuff the surfaces and knock down the raised grain from the previous step.
- wiped the surfaces with a slightly damp cloth to get most of the debris from sanding off.
- sprayed on primer (I like spray cans, so much quicker than brush)
- sprayed on 2 coats of enamel white (to make sure I got all the areas)
- put on a coat of spar urethane similar to Helmsman
I don't baby them at all. They've been out in the direct sun for the last 3 years in Vegas and still look great. I know your in a humid area, but this might work for you too. Hope it at least gives you an idea where to start.
Trying to keep all my fingers and toes
Personal site
fierysun is offline   Reply With Quote
Old 08-24-2007, 08:48 AM   #3
Thank you so much for your help.
I would not have thought to sand the chair!!
Appreciate the information.!!!!
Wanda
painting my floor Eli Flooring 3 03-20-2011 04:11 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Advicce on broken joint on wooden frame of chair markhod Carpentry 2 08-11-2007 08:48 PM
Painting Chair for Nursery cibula11 Painting 11 06-08-2007 08:39 PM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
