Painting Tile Backsplash - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 08:13 PM   #1
How difficult is it to paint a tile backsplash?
cattail is offline   Reply With Quote
Old 01-18-2009, 08:52 PM   #2
Registered User
Termite's Avatar
Not any more difficult than painting anything else I suppose (assuming it is cleaned), but why on earth would you want to? It isn't anything that will add appeal or value to a kitchen or bathroom...It'll look like painted tile!
Old 02-04-2009, 03:11 PM   #3
backsplash
For those of you wanting to paint a backsplash, this is what I painted in my kitchen, and I like it a lot. Plus, I redid the cabinets too.
Painting Tile Backsplash-backsplash1.jpg   Painting Tile Backsplash-backsplash3.jpg   Painting Tile Backsplash-backsplash2.jpg
foxie24 is offline   Reply With Quote
Old 02-04-2009, 04:22 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
How about an opinion from the middle ground?
First of all you need to realize the reason glazed tile is chosen for bathrooms, showers and backsplashes is because nothing wants to stick to it! This includes paint.
Painting shower or bath tiles is not recommended. Between the water and scrubbing they will peel.
You might get away with painting a backsplash if you do the proper prep work. This includes sanding it to give it "tooth", in other words a rougher surface for the paint to stick to, and also using a good bonding primer and a high quality paint. I would recommend going to a real paint store, Sherwin-Williams or Benjamin-Moore for suggestions, not a big box store.
Also keep in mind this will be a delicate surface, you won't be able to scrub it like the original tile. If it starts to peel it can end up looking a lot worse than what you have now.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Tile Backsplash - On Top or Behind Counter? Shandon Remodeling 10 06-10-2008 09:09 AM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 05:08 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 08:56 PM
