Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-20-2011, 07:18 PM   #1
Painting rough plaster
These are pictures from the top floor of a 1920s home I bought with what I believe is the original plaster. We scraped all loose paint and this is what we are left with.
Can I just use joint compound on the exposed plaster and sand so that it blends with the adhering paint! I'd prefer to not do a full skim coat bc I have no experience and don't have the time to learn that now.
Can I expect a decent finish by just speckling?
Also, can I use a latex paint regardless of what paint is on the wall now?
Painting rough plaster-image-1359524479.jpg   Painting rough plaster-image-3897306308.jpg
somuchjackson is offline   Reply With Quote
Old 07-20-2011, 07:58 PM   #2
From the close up, you aren't ready to paint or spackle. Any loose paint will contaminate the spackle phase by having pieces constantly breaking off and dragging through the compound. You need to remove all the loose flaking paint.
I'd tape all the cracks if you only want to do this once. Any compound only cracks will telegraph through in a short time.
If you don't know what paint category is on the wall, I'd prime the whole room first.
Ron
B. Franklin 1759
Old 07-20-2011, 08:27 PM   #3
Thanks. I've struggled with what it means to scrape flaking paint.
The fact is, if I try hard enough I can scrape all the way down to the plaster. But do I just need to get the LOOSE paint? How do you draw the line? We're painting the whole house so I'm trying to do enough to do a decent job but not so much that we're painting for 9 months!
So I guess my question is: how do you define LOOSE?
Old 07-21-2011, 06:38 AM   #4
Loose paint isn't adhered to the surface. If you compound over loose paint, it will lift off the surface as it dries.
Try an experiment. Compound a spot you think is ready. If it lifts, re-evaluate your process.
Ron
B. Franklin 1759
Old 07-21-2011, 07:18 AM   #5
Good idea, so I could expect it to lift the spackle in a day or two if it is too loose?
Old 07-21-2011, 03:41 PM   #6
paper hanger and painter
chrisn's Avatar
[quote=somuchjackson;690274]These are pictures from the top floor of a 1920s home I bought with what I believe is the original plaster. We scraped all loose paint and this is what we are left with.
Also, can I use a latex paint regardless of what paint is on the wall now?[/quote]
From here it looks like oil based paint, maybe not , but you will need to find out before priming.
Get some Goof off, denatured alcohol, nail polish remover and see if it comes off.
Old 07-25-2011, 11:54 PM   #7
Too Old
Save money and DIY Time tosee the pro
havalife is offline   Reply With Quote
Prepping plaster walls for painting phantasm72 Painting 11 07-03-2011 06:34 AM
Venitian plaster faux painting using drywall compound? crankcase Painting 3 02-18-2011 08:51 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
removing or covering paint on new unpainted rough plaster laakntna Painting 1 06-06-2009 06:23 PM
Painting rough Plaster deck hand Painting 4 11-29-2008 06:47 PM
