Painting Interior Trim - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 04:09 PM   #1
painting interior trim
hi, i was planning on sanding the polyurethane and stain off all my trim and restaining it a new color. well after 3 hours of sanding today, i realize, with the little free time i have, it will take me months to sand it all down. id rather just paint it a color similar to the stain i was gonna use. is it as easy as priming all the trim and just using an interior paint? will the primer adhere to the polyurethane? any answers would be appreciated. thank you.
Lethrneck4 is offline   Reply With Quote
Old 03-24-2010, 07:19 PM   #2
water flows downhill
oarfish's Avatar
Scuff it up or use wipe-on liquid sandpaper like "WillBond".
Use an oil based primer followed by top of the line latex or oil (old school).
I like the Zinsser's BIN primer applied 2 coats as an alternative for priming.
Did you want to achieve a lighter or darker stained/varnished look originally?
Only asking because you could save a lot of work by just scuffing up the existing finish and applying a toner polyurethane coat or two. It is essentially a polyurethane or varnish coating with stain solids added for the desired toning color.
oarfish is offline   Reply With Quote
Old 03-25-2010, 04:23 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 616
Why 2 coats?
chrisn is online now   Reply With Quote
Old 03-25-2010, 06:49 AM   #4
oarfish's Avatar
BIN is a thin coating when applied with brush, may not provide good base for the finish to grip on.
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 07:50 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 04:19 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
