-   General Discussion (http://www.diychatroom.com/f2/)
-   -   Paint fumes in house from garage (http://www.diychatroom.com/f2/paint-fumes-house-garage-66720/)
burnt03 03-13-2010 10:30 PM
My garage is at the front of the house, directly below 2 bedrooms.
Painted some boards this afternoon, left for a couple of hours and came home to a noticeably smelly house from the fumes.
My electric furnace is located in the garage.
So, the fumes are either migrating through the floor or the furnace is drawing air from the garage, which is more likely?
If the furnace, is there any way I can seal it up (tape all the joints, etc) so it won't draw air from the garage anymore?
Thanks in advance!
Scuba_Dave 03-13-2010 11:08 PM
Is it forced hot air ?
burnt03 03-14-2010 12:03 AM
Yes, forced air furnace.
Gary in WA 03-14-2010 02:07 PM
"So, the fumes are either migrating through the floor or the furnace is drawing air from the garage, which is more likely?"--- Could be both. If the joints are not taped for fire-stopping in the ceiling of the garage, or the fumes are entering through gaps in the intake ducting below the furnace. It could be drawing part of the supply air from the garage air, which is very dangerous.
Electric Furnaces
Electric furnaces are more expensive to operate than other electric resistance systems because of their duct heat losses and the extra energy required to distribute the heated air throughout your home. Heated air is delivered throughout the home through supply ducts and returned to the furnace through return ducts. If these ducts run through unheated areas, they lose some of their heat through air leakage as well as heat radiation and convection from the duct's surface.From: http://www.energysavers.gov/your_hom.../mytopic=12520
Hopefully, all the supply ducts are insulated in the garage, as well.
"If the furnace, is there any way I can seal it up (tape all the joints, etc) so it won't draw air from the garage anymore? " --- Yes, special ducting tape or mastic for ducting.
Be safe, Gary
burnt03 03-14-2010 02:22 PM
Thanks Gary, I'll try sealing it up and hopefully I'll see a bit of improvement.
Gary in WA 03-15-2010 10:53 PM
Glad we could help.... You might also try painting the garage inside with a vapor barrier primer paint, to stop any fumes or moisture from the cars getting to the upstairs heated rooms.
Be safe, Gary
