Oversized Lock Hole? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 09:30 AM   #1
Rewards Points: 270
Oversized lock hole?
Is there some kind of way to solve this issue. The inside hole is fine but the outside hole must have been done crooked or the hole is just larger than the inside side of the door's hole. Now there is a huge crack in the side of the replacement lock.
Do they make something special (like a large plate that goes underneath ??). Whatever came in the basic Shlage kit did not work. Maybe I could drill both sides larger?
pcampbell is offline   Reply With Quote
Old 06-27-2010, 09:44 AM   #2
they make a trim ring
The older I get the better I was
Old 06-28-2010, 08:14 PM   #3
Rewards Points: 270
I did not find anything at Lowes... should this be a standard part?
Old 06-28-2010, 08:26 PM   #4
the Musigician
DangerMouse's Avatar
I'd pull it and see if it's an adjustable length model.
If so, use the shorter length and it should set back in correctly.
If not, there are other ways around it as already mentioned.
DM
Old 06-28-2010, 09:24 PM   #5
DIY staff
Rewards Points: 7,174
I had a wood turner friend spin me an escussion after I blew a cut like that--Worked great!
Proper way to repair oversized outlet hole in drywall Plasmech Painting 16 06-24-2010 12:09 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
