Overhead Garage Storage??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-30-2010, 01:12 PM   #1
Have any of you folks built you own overhead garage storage? What did you use? Would you mind sharing any picture you may have. I'm looking for ideas...
Thanks!
mopowers is offline   Reply With Quote
Old 04-30-2010, 01:47 PM   #2
kwikfishron's Avatar
Rewards Points: 576
A picture of your garage would be a good place to start.
kwikfishron is offline   Reply With Quote
Old 05-02-2010, 01:34 PM   #3
Totally screwed together
I have a 4:12 roof in my garage, and not much room between the top of the garage opener and the ridge beam. 20'6" wide space. Here is what I did:
First I got 20' long 2x6 and carefully dried them until they were below 19% humidity. I then attached 1.5" angle steel to the underside using epoxy.
I made a ledger off each side wall 3" wide using 2x10 lag bolted into the studs. From there I used top hangers and set my 2x6 joists in there.
I have at max 4' vertical space next to my ridge beam. The floor is a little bouncy, but you're not going to have a dance up there! It's perfect for what I use it for: storage!
xxPaulCPxx is offline   Reply With Quote
Old 09-26-2010, 01:57 PM   #4
Why go to all the work and expense. You can buy steel drop-down 4x8' racks from Home Depot for about $70. All you have to do is bolt them to the ceiling joists. They hold about 800 lbs.
Patrick
California Concrete Restoration
www.squidoo.com/epoxygaragefloors
calconcrete is offline   Reply With Quote
Old 09-26-2010, 02:31 PM   #5
I didn't want to add to the load going across my garage door header. Any additional load to the roof gets transmitted to the header. I preferred having that load on the walls only.
Building Garage overhead Storage swenard Building & Construction 15 01-23-2012 02:01 PM
Building Garage Overhead Storage DirtSquirt Building & Construction 15 10-10-2009 09:41 PM
Garage storage, attaching to engineered beams jdcook72 General DIY Discussions 6 06-16-2009 11:01 PM
building storage in garage m98cox Building & Construction 5 04-13-2009 05:39 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
