Over The Range Microwave - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 11:43 PM   #1
Lenalocsta's Avatar
Over the range microwave
The cabinet above my stove is 18 inches in height. How would I go about installing an over the range microwave. Most microwave are 16 inches in height, at least the one I want. What can I do to make this work? SOMEBODY, ANYBODY PLEASE HELP ME!!!!!!!!!!!!!!!!!!
Lenalocsta is offline   Reply With Quote
Old 03-04-2012, 11:46 PM   #2
Rewards Points: 13,732
The distance from the stove top to the microwave needs to be at least 18".
Most cabinets over the stove are 12" high cabinets so they all match at the top.
A picture of what you have would use help.
Stock cabinets then just replace the one you have with a shorter one.
Lenalocsta (03-05-2012)
Old 03-04-2012, 11:51 PM   #3
Lenalocsta's Avatar
Ok, I will take a picture and load it.
Old 03-05-2012, 12:14 AM   #4
Lenalocsta's Avatar
I have no idea how to attach my pic of my cabinet.
Old 03-05-2012, 12:16 AM   #5
Lenalocsta's Avatar
I don't know how to load the pic. I'm new to this.
Old 03-05-2012, 12:20 AM   #6
Lenalocsta's Avatar
What are stock cabinets? Are they cabinets that are always in stock or something?
Old 03-05-2012, 04:56 AM   #7
You can upload your photo to a site such as PhotoBucket.com. Once you've uploaded it there you can post the link here.
Skull Leader is offline   Reply With Quote
Old 03-05-2012, 08:38 AM   #8
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Or just click on "attachments" if you don't want to upload it somewhere.
CoconutPete is offline   Reply With Quote
Old 03-05-2012, 08:46 PM   #9
Stock cabinets are cabinets that are premade, usually a quick measurement of your existing cabinets will give some indication of whether they are stock or not. Stock cabinets usually come in widths starting at 12" and increasing by 3" increments, so 15", 18", 21", and 24" are typical cabinet widths as well as any of these doubled, 30", 36", 48".
You will want to consider other things aside from the obvious question of dimensions and "will it fit?". You want to make sure that the microwave you are installing has a power source that is compatable. In new construction, the microwave is typically required by code to be on it's own, dedicated circuit. When replacing a microwave, you have to be careful when picking a new one to ensure that you aren't going to be tripping the breaker every time you feel like some popcorn. When installing a new microwave where there wasn't one before, I can almost guarantee that the local codes for new construction will apply. Like I said a moment ago, usually this means a dedicated circuit which, in your case, means installing a new breaker in your service panel and running new wiring to the oven location and either hardwiring the microwave or installing a new outlet. If you want the hood to exhaust to the outside of the house (as opposed to the more useless version that just blows the exhaust back into the kitchen) then you are talking about a fairly destructive process. Unless you are very capable electrically and mechanically, call a contractor. If you do it yourself, make sure you obtain the required permits for the work you will be doing. Where I live, you are permitted to work on your own home without being a licensed contractor, but the work still has to be permitted, inspected, and approved.
Tyman01 is offline   Reply With Quote
The Following User Says Thank You to Tyman01 For This Useful Post:
user1007 (03-07-2012)
Old 03-06-2012, 04:39 PM   #10
Rewards Points: 338
the first question would be do you have an electrical receptacle in the cabinet to plug the microwave into? without electricity, microwave no worky.
NitroNate is offline   Reply With Quote
Old 03-06-2012, 05:13 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
The second question would be....is the microwave your tying to install made for over the stove installation?
Third question....do you have an existing vent hood?
I suspect you have this empty cabinet above your vent hood....and you want to install a standard microwave in it.....well...if that vent hood vents to the outside, then you will most likely have an issue with the vent pipe.
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 03-07-2012, 08:40 AM   #12
Rewards Points: 3,130
Uh, over-the-range microwaves don't typically go inside a cabinet, they go underneath them and are mounted to the wall.
Old 03-07-2012, 10:48 AM   #13
Too Short? Cut it Again!
Where I live and have lived too!I happen to hate microwave ovens so may not be so sympathetic. You cannot cook anything on those small overhead things but evil looking gray chicken, twice killed fish, and carrots that turn a strange color not from the earth.
A set of good clad cookware and even a wok with a steamer will cook nice food on even an electric stove faster and with less energy and current worries about having to rewire and reconfigure your kitchen.
Not to bash you, but you do not need a microwave. Just a decent stovetop---gas or electric---and some nice cookware. No chef, for example, lets Mike cook the food.
Old 03-07-2012, 11:49 AM   #14
Yes, otherwise you bake the microwave gizzards and shorten its lifetime every time your cooktop is on.
A vent fan between the cooktop and microwave that runs when the cooktop is on may help this.
Old 03-07-2012, 11:54 AM   #15
JOATMON
ddawg16's Avatar
Ok....I read her post wrong....I thought she was trying to put a microwave inside the 18" cabinet.....
So it goes back to....is there and existing vent pipe?
Over the range Microwave geeman Appliances 6 08-04-2012 06:56 PM
Venting an oven range microwave demandrew HVAC 47 03-14-2012 06:15 AM
plugging OTR microwave into the range jpenns Electrical 13 01-30-2011 07:28 AM
OTR Microwave -> Range hood wiring A for Effort Electrical 2 07-31-2010 10:00 AM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 03:47 AM
