Originally Posted by Teetorbilt
Try to look at this rationally.
Your neighbors damaged your house just as surely as driving their SUV through the wall! It took longer and wasn't as violent but the damage is there just the same.
I know. That's exactly how I'm trying to convince myself to see this. I think the thing is, I try real hard to be a good neighbor. Even if it's tough. Most people would rather have their HOA, politicians, or a lawyer deal with this sort of problem. I don't want to be like that, and also don't want to stick them hard. I know they didn't try to do this, but in hind sight they didn't seem to care much. When we first moved in, I noticed that a few of our own sprinklers needed to be moved to point away from our other neighbor's home. The offending neighbors have their sprinklers pointed directly at our home, not away.
I would be very surprised if there is no structural damage. Anything this wet over a period of time has to have compromised more than one component. You can start with fasteners
You might be right. I'm not an expert and this is precisely why we're consulting damage recovery specialists. At first I thought I'd just dry out the wall and kill off the mold. That's why I first posted. Then I started thinking about it more rationally and realized that by ignoring any real problems I could be assuming a more serious problem down the road.
$4,200.00 sounds kind of on the cheap side and it will always look like a repair unless you have the entire side of the house re-stuccoed. I have never seen a decent 'blend-in' job.
The $4200 is just to dry it out, remove materials, and kill off the mold. It doesn't include any repairs to the structure, hanging new drywall, replacing insulation, etc. The second contractor today looked at it and said, "You have a real problem. This is going to be very expensive". I believe him. I'm starting to realize there is a lot of work involved.
Time to start loading the guns. I would hunt down previous owners and get affidavits from them, they can be supoenaed if it gets that far. Same with any other neighbors. Take pics of the offending sprinkler(s). Present a COPY of the package to the offenders and explain that they can play ball or throw your attorney's fees and court costs on to the bottom line.
The thing is, I learned about the previous owners and this issue from our neighbors that soaked the house. It's ironic that they set themselves up in a way. They posed it as the previous owners being crazy and unreasonable. I think the previous owners made the mistake of trying to solve the problem themselves and not consulting professionals. When we first moved in our neighbors said the previous owners hacked down some of their plants because they were causing moisture problems. The plants that were hacked are in the very same place. That wasn't a cool move on behalf of the previous owners, but it should have sent a signal to our neighbors that maybe there was something legit when they first mentioned there was moisture and took a hard stance and told them they were crazy. Now they'll most likely be paying for it and probably a lot more than they would have back then.
I'll bet next time they'll fix their sprinklers!
The thing is, there actually isn't anything wrong with the sprinklers. It never occured to them that pointing a sprinkler directly at someone's house from only two feet away could be a bad thing over a long time. Even when I asked them to turn on their sprinklers to see if it could be the problem they denied it was the source of the water even when they noted the water glistening on the side of the house themselves.
Anyway... I'm not trying too much to complain about my neighbors even though I just did. My stance has been changing on how to handle the situation. Your statement that the neighbors should pay for the problem only helps my resolve on it. So I guess this thread is no longer appropriate for a DIY forum. I will post back how everything goes, but I probably won't be doing any of the work myself. Even though I'm a huge DIY person.
Actually, I do have a question. Since mold is going to be a problem until it's resolved, I'd like to know if anyone knows of a good carpet cleaning product that will kill any mold in the carpet. Since I've been on the mold hunt, I noticed one of our entry ways probably leaks a bit when it rains. There's a small patch of mold in the carpet that I always thought was simply dirt. I'd like to kill it after fixing the doorway.
Thanks for your time posting. I appreciate it.
Cheers,
Scott
