Outdoor Lighting - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 07:44 PM   #1
outdoor lighting
I am looking for some kind of outdoor lighting like a flood light that I can attach to my garage so it is not so dark in my back yard when i have people over at night.
My issue is the garage has no electrical power source and solar power seems to provide very little light. Is there a battery powered light that can be used for this? I know battery power wont nearly light it as well, but I could use more than 1. I've tried googling many different searches, but no luck.
thank you
itl8 is offline   Reply With Quote
Old 04-27-2013, 08:45 PM   #2
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 173
I got a couple of these here and they have been working fantastic for about a year:
http://www.costco.com/Sunforce-Produ....11679366.html
Easy to install, maintenance free, very bright!
Cheers,
Deja-vue is offline   Reply With Quote
Old 04-27-2013, 08:49 PM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
Cheers,
Curious, how long does the battery normally last and is it regulated or does it fade?
fetzer85 is offline   Reply With Quote
Old 04-27-2013, 08:54 PM   #4
Too Short? Cut it Again!
Those LED solar floods are pretty nice if you have no electricity where you want them. So long as you do not have critters tripping the motion sensors on all the time. Some have sensitivity adjustments.
You sure you do not want to run an electrical line, either line voltage or low voltage, to hardwire something if you need a really bright light?
Battery operated lights will have you out there switching the battery every other day I fear or you trade brightness for battery life.
Old 04-27-2013, 09:08 PM   #5
Deja-vue's Avatar
Rewards Points: 173
They do.
Old 04-27-2013, 09:12 PM   #6
Deja-vue's Avatar
Rewards Points: 173
I have mine to stay on only for about a minute or so, it is adjustable.
Since they use LED's, (60 or so) they haven't faded since I installed them.
My Neighbor already complained that they are visible across my Yard, into his.
Like I said, they are extremely white and bright.
For the Money, a no-brainer.
Cheers,
Old 04-27-2013, 09:40 PM   #7
Rewards Points: 446
thank you
Look at low voltage outdoor lighting. They make a lot of different types of lighting styles and designs in low voltage. They run usually on 12v which makes it safer to run underground wiring say from the house? If not, you could possibly power them with a deep discharge marine 12v battery. Keep the battery charged up with a small solar charger. As long as you're not using the lights every night, should work fine.
old_squid is offline   Reply With Quote
Old 04-27-2013, 09:45 PM   #8
Those solar floods seem hard to beat if I needed some!
If you go low voltage, think outside the box and look at mast running lights, deck lights and things for sailboats and fishing boats. They may be cheaper than landscape fixtures.
I've found places like Big Lots have great prices on plastic fantastic low voltage lighting kits about now. The fixtures are horrible so you can throw those away (or rescue the bulbs and sockets and make your own lights) but the rest of the kits is often a cheap way to buy decent direct burial low-voltage wire and a basic transformer.
Old 04-28-2013, 09:47 AM   #9
PoleCat's Avatar
Rewards Points: 1,646
Sounds like you need good light for entertaining guests out by the garage at night. (we call that "drink some beers"). Personally I think I would use a Colman lantern.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 04-28-2013, 10:21 AM   #10
Apart from LED's, Halogen outdoor lighting produces excellent results. They offer the brightness and directional capabilities needed outside. Since halogen bulbs are relatively lasts long, they are getting popular.
leenamark1 is offline   Reply With Quote
Old 04-28-2013, 10:30 AM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,496
Getting popular? I doubt that. They use 6x more energy than LED's or 5x more than a CFL....and are a potential fire hazard because of the high heat.
ddawg16 is online now   Reply With Quote
Old 04-28-2013, 11:59 AM   #12
Deja-vue's Avatar
Rewards Points: 173
I beg to differ:
http://www.zytechledus.com/LED-light...ndescents.html
Old 04-28-2013, 12:15 PM   #13
JOATMON
ddawg16's Avatar
One little tid bit fact about halogens.....
The advantage of a halogen over the common incandescent is they are a little more efficient and last a 'little' longer than the incand. When you light an incandescent bulb, the tungsten starts to 'boil off' the filament. Basically, it's self destructing. That gray coating you see on the inside of a bulb is the tungsten deposited on the glass. The halogen gas in the bulb helps to redeposit the tungsten back onto the filament. For this to work right, you have to get the bulb hotter. I think the temp is something like 600 Deg C or so (need to confirm).
This high temp is one of the reasons for them being a fire hazard....and one of the reasons you can no longer buy one of those floor lamps with the bulb at the top.
When you use a tungsten lamp with a dimmer....if you run it at anything less than full brightness, you no longer have it hot enough and the halogen gas no longer does it's job....hence, the bulb is not going to last as long....and looses efficiency.
