Outdoor Kitchen Countertop - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-08-2013, 09:09 AM   #1
kemerick's Avatar
Rewards Points: 87
outdoor kitchen countertop
I'm in the process of finalizing the block placement for my counter top walls shown in the image below. I am wondering what type of structure to use for the counter top. I have considered concrete but have been told that it will crack and not stand up to time/weather. If I use rebar and concrete with fiberglass and pour it like 3" thick, shouldn't that suffice?
My only other idea was to use plywood with wonderboard on top with metal studs every 12" to support the wood. I hate the idea of using wood outdoors.
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 10-10-2013, 10:37 PM   #2
Yea I would go with what you are thinking. I'm not an expert in this field, but I would be very hesitant to use wood outside. Just my opinion.
kevinhart is offline   Reply With Quote
Old 10-11-2013, 03:43 PM   #3
K&B Designer
Live_Oak's Avatar
Why not tile? You could do a natural stone if this is in a weather protected location and you don't mind sealing. Or you could do a porcelain lookalike. Or a porcelain wood look. Or any of about a thousand different looks. I wouldn't do concrete around any cooking surfaces. It's porous and will absorb grease spatters and other food residue.
BTW, your design doesn't look like it uses the minimum recommended aisle space of 3'. 4' would be better. I'm also not really sure what the two different seating areas are for. Wouldn't it be better to have a single seating area done well than two that are "off"? What are your plans for ventilation for your grill since you show this as being in a covered area? And do you envision yourself actually doing a lot of food prep outside, or will all of the food prep occur indoors and then be carried outside? Because there's precious little space between the sink and cooking zone, and that's where all of the major work will take place.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
laminate countertop question photopeter Kitchen & Bath Remodeling 2 12-18-2011 03:32 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 03:07 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 05:56 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 08:05 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 02:08 PM
