Outdoor Grout - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 04:29 PM   #1
outdoor grout
I have irregular slabs of bluestone with gaps between the slabs of about one-inch: it's a large part of our Brooklyn backyard. It's rustic. Nevertheless, the gaps make it difficult to easily move chairs as some have become a bit deep. I've thought about filling the gaps with a small gravel, then a dry mix of sand and cement, then a spray of water. Instead, would you recommend a pre-mix grout or some other cement mix? I don't expect this to look like a finished bathroom floor: rustic, irregular slabs.
neri is offline   Reply With Quote
Old 08-07-2011, 05:08 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
I've used sand, super masonry cement and acrylic mortar admixture for large outdoor grout. Don't remember the mix ratio, its been a few years.
mustangmike3789 is offline   Reply With Quote
Old 08-07-2011, 10:19 PM   #3
Thanks. I imagine there would be some info as to mix ratio on the admixture material. I'll look for it at Loew's. I guess you used this where there was plenty of weather and foot traffic?
Old 08-07-2011, 10:21 PM   #4
Concrete & Masonry
Rewards Points: 568
Just curious what that means?
neri: Where you are located & the subsequent climate has a lot to do with what will work for you.
jomama45 is offline   Reply With Quote
Old 08-07-2011, 10:48 PM   #5
super masonary is a brand name of a stucco type cement in my area, florida and brocco are product names local around here. i believe that it is a mix of portland cement and lime to make it sticky.
Old 08-07-2011, 10:51 PM   #6
Concrete & Masonry
Rewards Points: 568
super masonary is a brand name of a stucco type cement in my area, florida cement is another product local around here. i believe that it is a mix of portland cement and lime to make it sticky.
OK got it. Just keep that extra "a" out of there ans all will be well................
