Out Swing Exterior Door? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 10:57 PM   #1
Out swing Exterior door?
I live in Ottawa, Ontario, in a 1960s house with an original wood side door, that opens onto a very small landing. I was hoping to gain some space by having a new steel out swinging door installed.
The contractor I talked to today said the water leakage warranty would not apply for out swinging doors. but other then that their were no problems.
I was wondering how big a deal is this possibility of water leakage? if there are any other issues with out swinging doors I need to worry about, and if maybe a fixed aluminium awning above the door might help with the water issue?
Thanks.
hswerdfe is offline   Reply With Quote
Old 09-12-2012, 11:09 PM   #2
Msradell's Avatar
Rewards Points: 132
The only other possibly issue would be the fact that you couldn't install a storm or screen door if the main door swung outward. Actually if installed correctly I don't believe water leakage will be much of an issue, especially if for a metal door.
Msradell is offline   Reply With Quote
Old 09-12-2012, 11:19 PM   #3
Rewards Points: 2,210
We've installed many outswing doors. Only issue has been snow piled up in front.
mae-ling is offline   Reply With Quote
Old 09-12-2012, 11:28 PM   #4
Rewards Points: 13,300
I've never seen any of the ones I've install leaking. In fact as the wind blows
It trys to close the door not open it like an inswing door will do.
All commercial doors have to open out.
Did he show you anything in writting from the maufacture that says that?
Now if you try to mount an inswing door backwards so it opens out it's going to leak because the threshold will be sloped wrong.
Old 09-13-2012, 03:32 PM   #5
Bombastic Idiot
notmrjohn's Avatar
" warranty would not apply for out swinging doors." "Did he show you anything in writting"
Sounds like an old gandy dancer chant...
"Contractor cain't read, contractor cain't write,
How's he gonna tell if the door's hung right?"
Slam it! oomph, slam it! oomph,
Salm it ope' an shut."
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-13-2012, 04:13 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
I've never heard anything so silly. I have two doors on my own garage that swing out. One on the north and one on the south, so they get blasted by storms from either direction. Both do have magnetic weatherstripping, but neither has ever leaked a drop.
Old 09-13-2012, 04:39 PM   #7
kwikfishron's Avatar
Rewards Points: 218
Originally Posted by hswerdfe View Post
are any other issues with out swinging doors I need to worry about ?
Just make sure you order the door with security hinges (non removable pins).
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
mae-ling (09-13-2012)
Old 09-13-2012, 06:16 PM   #8
Civil Engineer
Rewards Points: 4,580
Typically the contractor warrants his own work only. Supplied assemblies like doors, windows etc. are warrantied by the manufacturer against defects. Of course, the warranty generally does not apply if the door or window is improperly installed, and may not apply if the installer is not licensed by the manufacturer to perform the installation. If the installer is not familiar with proper installation procedures for an outswing door, you should find an installer who is, rather than being forced to install an inswing door that you do not want.
Daniel Holzman is online now   Reply With Quote
Old 09-13-2012, 06:54 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Make sure the outside landing is large enough. IMO minimum 4'by 4'. Bigger is better.
Coastal South Carolina
Old 09-13-2012, 09:01 PM   #10
Thanks for all the advice, it is much appreciated. I am planning on getting a third quote next week. and I will contact the other contractors about the issues mentioned (pins, threshold, magnetic weather stripping), giving them a chance to clarify their quote.
Any thoughts on hanging a foot pedal on porch swing? tabatt07 General DIY Discussions 1 07-25-2012 05:54 PM
Strengthen porch swing joists jakate General DIY Discussions 2 02-22-2012 09:40 PM
Will this vertical-posts Swing set plan work? diy_in_md Building & Construction 14 10-15-2011 11:06 PM
I bought a New Front Door, but wrong swing... Fisher252 Windows and Doors 8 06-09-2011 11:58 AM
Porch Swing nikeman Building & Construction 21 03-07-2011 08:15 PM
