Out Door Power - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 09:48 AM   #1
gmhammes's Avatar
Question
out door power
Quick question,
My saturday project this week is installing a sliding patio door where a bay window used to be to my back yard. I will be extending my deck to come to the door.
Heres the question. I currently have an exterior outlet on the back of my house, but eventually i may add deck lighting. I have the wall open now and was wondering if i could and or should drop power out to an exterior junction box now from a switch or if i can just tap the exterior outlet at a later time.
I am putting a single switch and light next to the door in the interior for a flood light however i was thinking of putting a double switch box there and keep one switch for the deck lighting.
Comments, questions, concerns? Please let me know your opinion on it.
gmhammes is offline   Reply With Quote
Old 05-08-2010, 10:08 AM   #2
Household Handyman
Rewards Points: 1,408
It sounds as if you have the interior wall open so the current wiring and boxes are exposed-I'll go that way. IF you are wanting your potential deck lighting to be switched, why not install the switch, wiring it, feed the load side out, and terminate it in a jb now for future use when/if you decide to do this. As far as the current exterior outlet, I'm not sure but it may be a code violation to tap an exterior outlet. In my area they have to be covered with one of those "up-to-date" covers which weight about three (3) pounds and make it hard to plug in anything, and have to be GFCI breaker protected. I like the idea that you are looking ahead, for sure. David
The Following User Says Thank You to Thurman For This Useful Post:
gmhammes (05-08-2010)
Old 05-08-2010, 10:23 AM   #3
I'd run the switch & feed now for the deck lighting
You can tap into an exterior outlet, they are not a required to be a dedicated circuit
I buy dual switches & use single gang boxes in some cases
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 05-08-2010, 11:25 AM   #4
gmhammes's Avatar
Perfect as always guys. I decided to do the double switches and instead of cutting it off into a junction box, decided to put another outlet out there that is switched (for now) later i can use that switched power for the deck lights.
Time to run some wire and close the wall.
Old 05-08-2010, 11:27 AM   #5
gmhammes's Avatar
Yeah the dual switches and single boxes i have in two of the bedrooms, it would work in this scenario however the gf said those confuse her. double box it is.
