Ordered Windows, Exposed Rough Cut Studs....whats Easiest Fix ??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 03:20 PM   #1
Question
ordered windows, exposed rough cut studs....whats easiest fix ???
ok so here's the deal. i have access to FREE #2btr planed lumber. i ordered my windows for the 2x4 framing, pulled down the 3 layers of walls to find rough cut fir. is there a way i can have the best of both worlds as i wasnt planning on changing much of the existing structure ( top plate etc) help please
Blueeyes is offline   Reply With Quote
Old 03-24-2013, 04:45 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Huh,..??..??
Old 03-24-2013, 10:15 PM   #3
Rewards Points: 13,748
Post make no since to me.
What's windows, free pine and ripping down wall have to do with each other?
What is it your trying to do?
Old 03-25-2013, 07:16 AM   #4
Lord of Slums
Rewards Points: 1,974
you could pull the wooden jambs off and just make your own for the windows.
mj12 is offline   Reply With Quote
Old 03-25-2013, 08:40 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,754
I am having a tough time figuring out what you are wanting as well.
Extension jambs can be fabricated and you can always fur out the wall too.
Post up a picture if you can.
Leaving a garage with exposed studs? dscamp Building & Construction 5 11-13-2011 11:49 AM
New Windows installed over old windows Lakehome Remodeling 1 03-14-2009 01:39 PM
buying Andersen windows charliebrown314 General DIY Discussions 14 03-14-2009 12:17 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
