Order Of Finish Work - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 12:31 PM   #1
order of finish work
I appologize, I'm sure this has been asked before but I haven't been able to find it by searching...
What order is ideal for the following work?
Installing prehung door
Installing door molding
Installing baseboard
Putting in finish floor
Thanks,
Greg
c00rdb is offline   Reply With Quote
Old 11-20-2010, 01:24 PM   #2
DIY staff
Rewards Points: 7,174
What is the finished floor?
If hardwood--or tile--Floor first--then doors--then casing--then base
jlhaslip (11-20-2010)
Old 11-20-2010, 02:51 PM   #3
jlhaslip's Avatar
Rewards Points: 2,820
if carpet, install in the above order, except no hardwood.
You may need to space the door jambs up off the sub-floor (see note below).
Space the baseboards and door jambs *about* 1/2" off the floor (depending on thickness) and have the carpet installed last. You want about 5/8" under the swinging door slab for interior doors to allow for air exchange.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-20-2010, 03:51 PM   #4
i would do floor, door, baseboard, casing.
1910NE is offline   Reply With Quote
Old 11-20-2010, 05:03 PM   #5
DIY staff
1910NE--if you do the base before the casing---how would you know where to stop the base for the casing?--
Old 11-20-2010, 06:07 PM   #6
firehawkmph's Avatar
Rewards Points: 1,902
Ditto,
Case before base, I before E, except after C,.........
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 11-20-2010, 10:37 PM   #7
in that case
should the floor go in before the drywall too then?
Old 11-21-2010, 06:09 AM   #8
DIY staff
NO--get that mess done before any finishes are installed--
I like to see the walls and ceiling primed and first coat of paint before the trim. Final coats of paint after trim is in and caulked.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
Finish my basement - Need some help on a quote Constructacon Building & Construction 1 10-15-2009 09:08 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
