Orange Peel Drywall Texture - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 10:23 PM   #1
Please help! I'm trying to duplicate the orange peel texture that is on ALL the drywall throughout my house.
I bought a Kobalt 3-ft Gravity Hopper Gun at Lowes
and
Bostitch 6 gallon air compressor
Thus far everything has turned into an epic failure. I thinned out my drywall mud and mixed it to the consistent of pancake batter. I also turned to PSI of the compressor down to about 25PSI as recommended in the manual for the hopper. However, the mud does not "spray" out the gun, more like it drips on the floor. I tried cranking the compressor all the way up (PSI) and then it just drips out at a higher rate of speed. What am I doing wrong? Do I need a different compressor?
calirtc is offline   Reply With Quote
Old 04-16-2013, 10:34 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Is the air controller that's on the hopper turned up all the way?
Sir MixAlot is online now   Reply With Quote
Old 04-17-2013, 08:43 AM   #3
Rewards Points: 13,300
For one thing your trying to use a compressor that only has the ability to put out 2.8 CFM and a tool that needs 7 CFM to work right.
Old 04-17-2013, 09:15 AM   #4
Rewards Points: 876
True. But, I have that same compressor and it will spray orange peel for just a repair. It wouldn't be able to keep up if he's trying to spray texture a whole room though.
Old 04-17-2013, 10:07 AM   #5
Ummm I get this texture using cheap rollers, just gotta go over it a few times while it's wet and it happens everytime.
TheJerk is offline   Reply With Quote
Old 04-17-2013, 10:19 AM   #6
Rewards Points: 876
Maybe at your own home. Not at a customers.
The Following User Says Thank You to Sir MixAlot For This Useful Post:
ToolSeeker (04-17-2013)
Old 04-17-2013, 02:36 PM   #7
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 159
It definitely sounds like the Hopper Gun is not getting any or enough Air to it.
I textured my entire Kitchen last week using the same Tool, the PSI on my Compressor is between 30-35 and it doesn't drop.
One time, however, I kinked the Hose and the Stuff started to "drip" in big globs, luckily I noticed it right away.
So check if you get enough Air.
I usually place a piece of Scrap Drywall out in the Yard and do some "test-spraying" to find the correct Mixture/Coverage/Texture.
BTW, I am using the smallest Nozzle. (I believe the Tool came with a small, medium and a large one.)
Deja-vue is online now   Reply With Quote
Old 04-18-2013, 05:47 PM   #8
Rewards Points: 744
If you don't have much texturing to do, just buy a few of the aerosol cans.
Seattle2k is offline   Reply With Quote
Old 04-18-2013, 05:55 PM   #9
I appreciate all your help and was able to figure it out. The air hose that came with my compressor was bad, so the hopper wasn't getting enough air. Also, the aerosol stuff sucks! Terribly expensive and looks awful! I bought a can for a few touch ups but no thanks.
Old 04-19-2013, 08:44 AM   #10
Household Handyman
Rewards Points: 1,408
Interesting--I've seen those "hopper guns" used to make pop-corn ceilings but never seen them spray an "Orange peel" texture on a wall.
Old 04-19-2013, 09:31 AM   #11
Rewards Points: 5,974
You need to buy the ones that say for orange peel. Also have them for knockdown. Sorry I thought you meant the cans. To get the hopper guns to do it you need the nozzle for orange peel. The 3 nozzles that came with it should say what they are for 1 for orange peel 1 for knockdown 1 for something else or they could just be small, medium, and large and you get different patterns by adjusting the air pressure.
Tags
drywall , mud , orange peel
Drywall and texture in bathroom mikeypellman Drywall & Plaster 5 04-10-2013 07:11 PM
Drywall texture? Yeti Painting 13 02-09-2013 03:08 PM
orange peel? Startingover Painting 7 06-15-2012 07:32 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
What to use to spray texture on new drywall? klemmy Remodeling 16 03-28-2007 07:14 PM
