-   -   Open shelves in kitchen (http://www.diychatroom.com/f2/open-shelves-kitchen-25923/)
gorf 08-28-2008 09:55 PM
I have completely gutted our kitchen. We have come up with a design that we like. One wall pantry/stove/microwave/frig. The opposite wall gas cooktop with stainless range hood. No upper cabinets. Instead on one side of the range we would like two or three open shelves. I do not want visable brackets, I want the shelves to look like they are floating.
Are there commercially available shelve units like this? Where do I shop them?
Or if I build the shelves, how are they hung?
Termite 08-28-2008 11:04 PM
If you've got the wallboard stripped off, you could bolt some steel plates to the side of the studs. I'm thinking something about 2" wide, 1/4" thick, and as long as the shelf is deep. Accounting for the width of the stud, something about 14" would allow you to put a box-shaped shelf over the steel plate once the wall is rocked, and it would stick out of the wall about 11". A steel fabricator could easily make them, and drill a couple bolt holes in them for you. Then you'd just slide the wooden box shelves over them.
Hope that's understandable.
The other option is to screw a wooden cleat (like a 2x2) to the wall, and attach wooden box shelves to the top of the cleat with some trim screws screwed down through the top of the shelf. This would work for light storage but wouldn't be something you should put 200 pounds of canned goods on.
JohnDIY 08-29-2008 12:13 PM
There are shelves like that commercially available but I'm not sure if they would be up to the task. They tend to be aimed at the bedroom/living room and as thekctermite says they might not hold a great deal.
gorf 12-04-2008 05:18 PM
Thanks - my final solution is very very close to your suggestion.
24 inch piece of mild steel 2 inch x 1/4 bent 90 degrees. Notched out the studs 1/4 so the sheet rock would lay flat. counter sunk screw holes and screwed the brackets to the studs. Shelves are two pieces of 3/4 with a slot cut in them for the brackets. Looks great and is fairly strong.
Termite 12-04-2008 09:42 PM
Great! Thanks for following up and letting us know how it worked out. :thumbsup:
