Older Model Campbell Hausfeld Air Compressor Value ??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 07:00 PM   #1
older model campbell hausfeld air compressor value ???
after my grandpa died i was given one of his air compressors, a campbell hausfeld model VT559501 230V. Took it into a shop and had the gasket replaced and was told this is one of the oldies but goodies, it runs great but i cant use it and i need to know the value of it so i can put it up for sale........i can't find any values of it.....at all,
help please
nicholstwo is offline   Reply With Quote
Old 01-23-2012, 07:11 PM   #2
Rewards Points: 13,458
Not much. The older it is the less likly there's parts for it.
It's 220 volts and that will make it harder to find someone to buy it.
Go on Craigs List and look under tools for some ideas.
Old 01-23-2012, 08:05 PM   #3
thats not what i have been told..........but i understand, thanx.....anyone else???
Old 01-23-2012, 08:09 PM   #4
when i had it gone thru they said it should last for quite a long time, i understand what u mean by parts, but i do believe they will have interchangeables............thanx...............an yone else have any suggestions
Old 01-23-2012, 08:15 PM   #5
Have you looked on Craigs list under tools?
Also check on ebay to see if there's something like it.
nicholstwo (01-24-2012)
Old 01-23-2012, 08:28 PM   #6
How old is old. Tanks rust thru!
Hardway is offline   Reply With Quote
Old 01-24-2012, 12:26 PM   #7
don't know exact age, he died about 8 years ago and compressor was used untill then...... wasn't stored with anything in the tank, i believe.....don't know when he bought it, would the serial number help ?
Old 01-24-2012, 12:55 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Ayuh,.... Probably Not....
The tank badge should list the gallon capacity of it, 'n possibly the Cfm's of the compressor...
The motor badge should list the horsepower, maybe...
An old compressor is worth Exactly what somebody's willin' to pay for it...
Scout out some ads, 'n see what other folks are askin' for compressors 'bout the size of Granddad's, 'n ask that...
Then settle for whatever ya get beat down too...
Sellin' points are tank capacity, 'n horsepower/ Cfms....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Old 01-24-2012, 01:44 PM   #9
The tank tag will tell when the tank was built.
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
The Following User Says Thank You to Hardway For This Useful Post:
Tags
air compressor
Campbell Hausfeld 2030 Pressure Washer Problem 68rs327 Tools 3 11-09-2011 10:04 AM
Campbell hausfeld air compressor wont start Steve12 Tools 25 03-04-2011 08:17 PM
2 gallon air compressor combo - Campbell Hausfeld or Husky? whataboutj Tools 3 11-26-2010 02:31 PM
Bostitch VS Campbell Hausfeld nailers. Jim F Tools 4 04-25-2010 01:50 AM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 07:04 PM
