Old Window Locks - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-16-2009, 04:57 PM   #1
Question
old window locks
Can you advise regarding an old window lock that cannot be opened because the client has lost the key. The lock is on a handle and has allen key screws by four screws two of which are covered by the handle. Thanks
targa is offline   Reply With Quote
Old 06-16-2009, 05:57 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I would use a Dremel Tool to cut it. Dremel has a new Cut-Off wheel that I used to cut through 2" angle iron with NO appreciable wear on the wheel.
http://www.amazon.com/Dremel-EZ406-C...093916-3409400
The old type wheels had tiny screw to hold the wheel to the mandrel that I could NEVER get to work right. Their new system is not only simple, but the cutting wheels now seem to last & last.
They also have Cut-Off Wheels for plastic
http://www.amazon.com/Dremel-EZ476-2...665153-9273610
And even a Diamond Wheel
http://www.amazon.com/Dremel-EZ545-2...665153-9273610
To remove the EZ Lock Wheel you just engage the shaft, push the wheel down slightly, turn the wheel Turn, and it pops off.
Disclaimer
& Stay Safe
.....Bob Lavery
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Window Sash Locks Won't Latch roztom Building & Construction 2 09-05-2008 05:44 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
